Like Tree2Likes
Old 10-30-2012, 08:27 PM   #556
Hey guys. I need help with the correct shorty battery pack selection. Reedy has 2 options that I am considering.
4000mah 60C
Dimensions: 94x47x25.1
Discharge: 60C Cont, 80C Burst
Weight: 202g
or
4100mah 65C Competition
Dimensions(mm): 96x47x24.8
Discharge: 65C Cont, 120C Burst
Weight: 211g
TCS Rookie is offline   Reply With Quote
Old 10-31-2012, 04:27 AM   #557
dfx
dfx's Avatar
Originally Posted by InspGadgt View Post
I Shoe Goo the servo in so I don't have any problems with the servo moving. I will say don't use the set screws the Exotek has to hold the servo in place as they just seem to pinch the servo.
+1 ...but I use Tamiya double side tape (which is a bit thicker than others). The shape of Exotek is useful when Kimbrough saver is used. If You use laid down servo setup and Kimbrough saver steering links collide with stock servo holder...
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 10-31-2012, 09:31 AM   #558
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
4000mah 60C
Weight: 202g
or
Weight: 211g
Honestly, either one is fine. You won't get any advantage. The funny thing is, I have the Reedy 4000 and an Losi Exceleron 3800 that I bought brand new. I cycled each one, twice, and found that the Losi had better numbers. Both had about the same mAh, but the Losi had a lower internal resistance.
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 11-05-2012, 07:19 AM   #559
celt's Avatar
Default shorty pack mounting
Looking to purchase this kit and have decided to use my existing shorty packs.
Is there a preferred method in securing these? For example, I don't see a rear stop, or a second set of mounting holes in the rear of the chassis should you want to attach the ESC in the rear. I would assume you don;t want the battery slamming into your ESC in the event of a hard impact.
Just curious on what those using shorty packs have found to work best.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 11-05-2012, 10:38 AM   #560
It is possible to secure the battery with battery tape, the chassis has 2 long cut-outs for using the battery tape.
addicted2blue is offline   Reply With Quote
Old 11-05-2012, 11:03 AM   #561
JayL's Avatar
shorty pack stop: I shoo-goo'd a plastic bar, an old servo horn, on the chassis in front of my rear mounted esc to stop the battery, and I use tape
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 11-06-2012, 06:27 PM   #562
spring71's Avatar
Smile
Rector high traction system for F104V2 is available
FYI, thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 11-07-2012, 02:48 PM   #563
been on the fence for the V2. Question is, will my lap times get better from my f104? Running on outdoor asphalt treated with sugar water using rubber tires.
this is my track
+ YouTube Video
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 11-07-2012, 03:03 PM   #564
I thought you were running a V2? I'm planning on running my F1R in the next race and if it does better than my FGX I will probably pick up a F104V2 after that.
Old 11-07-2012, 03:05 PM   #565
nah. it still is a stock f104 with some options.
TLR 22 3.0
Apex RC Proshop
Old 11-07-2012, 03:11 PM   #566
240Z's Avatar
v2 will seem more consistent on a medium to low traction surface where you need that extra rear stability.
Better lap times? .... depends upon what you are dealing with on your v1. In the end, a better driver makes for better lap times.
I don't always race RC, but when I do, I prefer "UF1 format".
240Z is offline   Reply With Quote
Old 11-08-2012, 11:14 AM   #567
TRF Shock Help?
I'm racing at the Tamiya Track in Aliso only so that setup is what I am trying to achieve. I have the setup sheet from Fred off of the website. I am planning on using 30wt with the standard spring that comes with the TRF 53901 shock (White spring with the red marking on top).
My question is which disk is best to use? The one with 2 holes or 3 holes?
Thanks for the help.
Old 11-08-2012, 12:36 PM   #568
racer x 1's Avatar
Trader Rating: 27 (100%+)
You are going to want the 3 hole piston. Im not sure on what weight oil would be ideal.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 11-11-2012, 09:06 AM   #569
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
What do you guys think of this????
http://www.tqrcracing.com/shop/produ....asp?p_id=4742
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 11-11-2012, 10:06 AM   #570
Dan
Dan's Avatar
Trader Rating: 47 (100%+)
Wonder how those compare to Shimizus
Dan is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
