Tamiya F104 Version 2
#515
Was planning on racing this weekend so kinda need a quicker fix.
I was thinking of using the kit knuckles and just pull the axles out, enlarge the whole for the RSector axles, and drill out the ballstud hole.
Also, on the 190mm kit for the rear, I have a lot of side to side play in the axle. About 2mm of movement. Do I need to just shim it or is something not assembled right?
#516
big sweepers wear out my left side tires fast. Anyone try swapping pits 571/572 left to right?
#518
#519
Hi,
I'm new on Formula class, really like this chassis. I want to built a good car for fun and maybe some competition. Please let me know your opinions or recomend me some stuff for built it.
What I need for built it with 17.5T motor?
#520
#521
Hello, my VII had push problem to enter corner always. my setting is
Front ride high 5mm, sliver spring, camber 2 degree, front droop about 0.5mm, center spring stock golden, damp oil stock, side spring golden, side damp oil stock. Rear chassis ride high 5mm, droop 1mm. Motor pad ride high 6mm, droop 1mm. Shimizy tire Front 571, Rear 579. Anyone can help me? Thank you in advance.
#522
Here´s probably everything You want to know
http://www.tamiyausa.com/articles/fe...article-id=613
Thanks for reply. An additional question, can I use rubber tires directly on kit wheels?
I'm thinking on MP24 body and not sure if wings are included.
#523
On the kit rims you can use these rubber tires:
Tamiya F1 Tire Front Soft (#1031) or Pit Shimizu Racing #PS-0571
Tamiya F1 Tire Rear Hard (#1032) or Pit Shimizu Racing #PS-0572
Or any Pit Shimizu Racing tires for the F104:
http://www.tqrcracing.com/shop/parts...arts_p_id=4321
How to glue shimizu F1 tire and Tamiya Foam wheels:
http://www.rctech.net/forum/10130806-post93.html
F1 rc tire guide:
http://www.rcformula1.com.au/index.php/tech-tips/tyres
F1 rc tire guide:
#524
#525
Hi
I'm building my shopping list. I've a question about motor mount.
What is the difference between Yeah Racing Motor Mount SinglePiece and TAMIYA aluminum motor mount?
What do you recommend me?
This is the list, I'm open to any sugestions. Thanks
58534 1/10 F104 Version II Chassis Kit
51430 Body Set Vodafone McLaren - Mercedes MP4-24
PS-0575 F104 Rear R1-Soft (1 pair) with inserts
PS-0573 F104 Front F1-Medium (1 pair) with inserts
54357 Adjustable Metal Upright - F103 F104 RM01
54356 Aluminum Motor Mount - RM01
F104-039BK Aluminum Servo Mount Set (2 pcs) (BK) for Tamiya F104 Pro / F104 V2
54375 Carbon Rear Bulkhead Plate - RM01 / F104 V2
54351 Carbon Damper Mount Plate - RM01 Rear
54352 Roll Spring Set - RM01
54159 Hi Torque Servo Saver Horn - F104 Aluminum/Blue
51000 Hi-Torque Servo Saver - Black
Savox SC-1251MG Low Profile Digital High Speed Metal Gear Servo .09/125.0
306 Associated Reedy LiPo 2S 7.4V 4000mAh 60C - Shorty Pack
