Old 09-20-2012, 01:53 AM   #466
dfx
dfx's Avatar
Originally Posted by RedBullFiXX View Post
Will have to double check
But I think 2 o-rings in normal X-1 length, or 1 oring with rally shaft for longer Vii length TRF shock
When setting up a new shock length I leave the oil out until I have everything set how it should be
OK, Thank You!
How's working that setup from your picture with longer plastic ball joint and overturned shock position on the track?
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 09-20-2012, 04:22 AM   #467
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by dfx View Post
OK, Thank You!
It works more like the kit aluminum damper, but with 100% reliability
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-20-2012, 05:15 AM   #468
dfx
dfx's Avatar
Now I'm confused. Could You please describe the difference? Are there any problems with stock (V2/RM-01) damper?
I'm afraid that I'm not able to test all setups properly at the moment so any advice appreciated.
Tamiya TRF 416 WE
Old 09-20-2012, 08:30 AM   #469
We race on a lot of rough outdoor circuits in SoCal
The TRF shock is more sturdy
No oil weeping out, spring sag, etc
For indoor tracks the VII/RM shock is great though, and lightweight
Old 09-20-2012, 10:16 AM   #470
BangkokBulldog's Avatar
Ive got to agree that the standard V2/RM shock could be improved. I usually have to top up with oil most weekends. Great car though!
BangkokBulldog is offline   Reply With Quote
Old 09-20-2012, 01:54 PM   #471
malcnz's Avatar
I am liking the TRF shock...can find softer springs easy and more oil volume is a good thing.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 09-21-2012, 03:31 AM   #472
dfx
dfx's Avatar
OK, thanks!
How about some damper grease to stop the oil leak... I use it for silicone o-ring and rubber cap in TRF shocks and it works well.
Tamiya TRF 416 WE
Old 09-21-2012, 08:38 AM   #473
Same here, i've always used tamiya damper grease and the leaking is much better. Never had problems with my dampers so far.
addicted2blue is offline   Reply With Quote
Old 09-21-2012, 11:31 AM   #474
Default Tamiya springs and damper oil
Anyone know if Tamiya oils are rated on cst scale or if they compare to other companies oils such as AE oils?
Same for their TC springs, does anyone know what their spring ratings are for the springs used on their TRF shock?
Thanks!
r450racer is offline   Reply With Quote
Old 09-21-2012, 11:36 AM   #475
OK, thanks!
Thanks for the tip, will try tomorrow.
Old 09-21-2012, 11:39 AM   #476
JayL's Avatar
Is there a SIDE spring chart anywhere that has the Tamiya and AE and CRC spring rates?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 09-23-2012, 12:02 AM   #477
mikeygar's Avatar
Trader Rating: 14 (100%+)
guys, about the 'football'/pivot joint between main chassis and rear pod, are you guys doing anything to reinforce it from popping out? It seems if it pops out once, then it'll keep on popping out and/or bind up while running. The plastic needs a carbon reinforced upgrade for guys like me who do aerobatics... :-(
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 09-23-2012, 12:18 AM   #478
Haven't had any issues on my car yet
But if it pops out once, it is damaged and should be replaced
Old 09-25-2012, 07:24 PM   #479
Autocratic's Avatar
Trader Rating: 26 (100%+)
What longer ballstuds are most people using for the laydown servo setup?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 09-26-2012, 03:31 AM   #480
dfx
dfx's Avatar
Is it better with damper grease? I have no experience with V2 shock at the moment... I'm going to build mine this weekend.
Longer screw, alu shims and Tamiya fluorine ball nut.
Tamiya TRF 416 WE
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
