Like Tree1Likes
Old 09-18-2012, 09:18 AM   #451
Originally Posted by RedBullFiXX View Post
When using Alu upright, run spacers on top, never on bottom
Adjust droop with screw, and shims on lower A-arm
What would be the advantage of running like that in place of putting shims under the upright?
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 09-18-2012, 09:47 AM   #452
Ok need some help. V2 will pull hard in the rear from one side to the other. Very unpredictable. Medium traction carpet.
Huskerfan1212 is offline   Reply With Quote
Old 09-18-2012, 10:02 AM   #453
JayL's Avatar
RedBullFiXX: thanks for the tips, I finished 3rd in this weeks series race thanks to your tuning tips, I was 12th last race
I went to pink side springs and got alot more corner entry, now the car wants to keep turning on exit, slightly stiffer side spring? In touring I would go little thicker rear gear diff fluid
Are the AE black side springs softer OR stiffer than Tamiya pink side springs?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 09-18-2012, 11:42 AM   #454
Jay, I was running my X1 this past weekend, but will probably go back to the V. 2.0 for Ripon. I think I had everyone on the motor department this past weekend and was visibly faster than everyone on the straights, but I was having a little inconsistency with the handling on the X1, or maybe I was hitting that bump consistently at end of the straight that it would just kick the rear of the car out every time.
If there's time, I'd like for you to drive my V2 so I can get some opinions on overall handling--will probably go back to the Cirtix 21.5 so I can have some drag brakes back on the car--I was running silver can the past two races.
--Rene
TwoWheel is offline   Reply With Quote
Old 09-18-2012, 11:43 AM   #455
DerekB's Avatar
Hopefully all the F104v2 and F1 fans in general have checked out the latest issue of Velocity RC Magazine. F104v2 on the cover, 10 page review, and an F1/Tamiya history article!
http://vrcmag.com/current-issue/
www.vrcmag.com
DerekB is offline   Reply With Quote
Old 09-18-2012, 01:55 PM   #456
JayL's Avatar
--Rene
Ah, now I know your screename/face I would be happy to try your car.
I have been trying all sorts of things. I switched from an X1 to the V.2 as well.
I did not run any drag brake at Speedworld
Old 09-18-2012, 03:07 PM   #457
dfx
dfx's Avatar
How are You building the TRF shock for use in V2? I have 1 black o-ring on the shaft in shock used in my Pro wide car (I believe stock setup for X1 and WGP cars), is it still long for V2 and outdoor unprep. large track?
Tamiya TRF 416 WE
Tamiya F104 Pro wide and F104 Pro V2
dfx is offline   Reply With Quote
Old 09-18-2012, 03:23 PM   #458
robk's Avatar
Trader Rating: 22 (100%+)
Side springs? Tires? We need more information on what you have right now- run down your setup
Old 09-18-2012, 06:29 PM   #459
Pink side springs. Tcs tires. Black spring. 900. 400 For the other. I hope to tweak it a bit better tomorrow and see if that helps. Pretty much set up with the tq set up.
Old 09-18-2012, 06:48 PM   #460
F104v2 still fast enough to beat 200mm cars. But of course, if the driver used 200mm he would probably go even faster.
+ YouTube Video
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 09-18-2012, 08:14 PM   #461
hey i have a question is it possible to tilt my servo(standard servo) back to remove the bumpsteer is there enough room??any ideas ??thanks
tamiya-2012nz is offline   Reply With Quote
Old 09-18-2012, 09:51 PM   #462
robk's Avatar
Try silver side springs.
Old 09-18-2012, 09:52 PM   #463
robk's Avatar
You will probably need to space the links down even if you tilt the servo
Old 09-19-2012, 02:45 AM   #464
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Apex View Post
So is the F104 ver. II Tamiya F1 kit the kit to have for asphalt and carpet? I have an X1 that tq'ed and won the Frederick, MD TCS race this year. Do I need to unload the X1 or will the X1 still be competitive?
The X1 can still be competitive, as it narrowly edged out a VII at TCS Nats this year, personally, I haven't run my t-bar car much since the VII came out, as I like the extra fine tuning available with the VII
Martin Paradis
Shim on top are there to adjust ride height, shims on the bottom really have no purpose
With the alu uprights, the grub screw sets and holds the kingpin, there is no need for shims under the upright, and in the case of a big shunt, having shims under the upright have caused the lower pivot ball to pop out
Have a look at this video from RobK about link setup, it's possible something is bound up on your car
What tire sauce are you using ?
Start with half sauce up front, full rear, add sauce up front as needed for steering, too much sauce, or letting the sauce soak too long could cause the car to be very unpredictable
I normally sauce the tires for 10m or less
Also can you post some pics ?
www.rctech.net/forum/11009668-post240.html
grats
Loose on power, or just doesn't center up after the apex ?
Might need 1 turn down on pink side springs for a bit more pre-load, if the springs are backed off too much the car will wander a bit
Heavier side damping can help, 20-30k, but too heavy and the rear will become vague, and loose grip
Will have to double check
But I think 2 o-rings in normal X-1 length, or 1 oring with rally Shock end for longer Vii length TRF shock
When setting up a new shock length I leave the oil out until I have everything set how it should be
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-19-2012, 09:47 AM   #465
JayL's Avatar
grats
Doesn't center up. I set the spring to just touch, like I usually do in 1/12.
I was thinking more/some preload as well
Tamiya F104 Pro! NT Electric On-Road 9352 04-22-2017 06:01 AM
