Like Tree2Likes
Old 09-16-2012, 07:30 PM   #436
Autocratic's Avatar
Trader Rating: 26 (100%+)
What's a good starting setup for this car on high carpet?
-I have the option trailing axles, and not sure what spacing I need, as they are thinner than the stock axles and require more spacers.
-What oil should I start with, and what oil am I supposed specification am I supposed to use? (WT or CST)?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 09-17-2012, 01:39 AM   #437
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Carpet Setup
Also check the VII link in my sig for build tips
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-17-2012, 07:34 AM   #438
Autocratic's Avatar
So when someone's setup says "900#" oil, is that Tamiya's spec? If so, what would that convert into AE weight oils?
When "upright spacers" says 3mm, is that supposed to be under or over the steering block?
Old 09-17-2012, 07:41 AM   #439
900wt is the clear oil incll with the kit, not sure, but is similar to AE
When using Alu upright, run spacers on top, never on bottom
Adjust droop with screw, and shims on lower A-arm
Old 09-17-2012, 09:04 AM   #440
On my way to hobby store to get mine rite now.
Huskerfan1212 is offline   Reply With Quote
Old 09-17-2012, 09:04 AM   #441
Need a setup for lower traction carpet
Old 09-17-2012, 09:27 AM   #442
Autocratic's Avatar
Can I run the option uprights with the factory kingpin? The option shows two slots on paper for e-clips in the middle. The factory only have a ring for the set screw.
Old 09-17-2012, 10:06 AM   #443
Yes, with option uprights, e-clips are not used
Old 09-17-2012, 10:16 AM   #444
Autocratic's Avatar
So, correct install should be:
-top e-clip > pivot ball > 3mm spacer > upright > bottom pivot ball > spring > bottom e-clip
And then set the upright against the spacer and tighten set screw?
Old 09-17-2012, 11:11 AM   #445
Yes
Tamiya F104 Version 2
Old 09-17-2012, 02:30 PM   #446
theatriks's Avatar
Now thats hilarious
theatriks is offline   Reply With Quote
Old 09-17-2012, 04:56 PM   #447
Just sharing, from our Singapore GP. Out of 27 racers, the F104 v2 of Taka takes the win (even over a bunch of F103s). But of course, the driver is a monster.
Steering wheel trophy is made of glass.
Photos and event writeup here.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 09-18-2012, 12:23 AM   #448
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Guys, putting my v2 car together - can I use a regular 64p spur? Looks like there is an off set. Thanks for any info.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 09-18-2012, 12:28 AM   #449
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Yes you can, just need the spur gear adaptor from Tamiya. I'm using Kimbrough spur gears on my V2.
Dan is offline   Reply With Quote
Old 09-18-2012, 09:57 AM   #450
Trader Rating: 45 (100%+)
So is the F104 ver. II Tamiya F1 kit the kit to have for asphalt and carpet? I have an X1 that tq'ed and won the Frederick, MD TCS race this year. Do I need to unload the X1 or will the X1 still be competitive?
Apex is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
