Like Tree1Likes
Old 09-05-2012, 07:51 PM   #406
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by k4mp4q View Post
My setup is black spring in front, yellow on side spring with 200 oil...
Black spring with 900 oil on pitch damper
Ride height 4,5 front and 6 on the back with droop 1 all around
Using tamiya rubber soft on back and standart rubber in front
Ok couple problems here...
Are the tires these:
or these:
If you are using the second tire, they don't work on carpet very well and any setup will not be helpful.
Old 09-05-2012, 07:53 PM   #407
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
You need tires that work on carpet
The ones you have, do not
Try the new Tamiya TCS tires, or Shimizu 571, 572 combination
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-05-2012, 09:06 PM   #408
or these:
well i'm using the second picture tire...the tcs and shimizu not available in my country.....
i understand the tamiya not good on the carpet...but i'm using tire warmer and it do get a lot of traction. even sometime traction roll...
lets hope the tcs will be available soon in my country..what will be the good set up..
thanks
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 09-06-2012, 04:05 PM   #409
JayL's Avatar
RedBullFixx: you seem to have the same servo as me, Futaba BLS-551: How much shims under the servo saver for no bumpsteer AND how far forward or back for correct ackerman?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 09-06-2012, 07:59 PM   #410
robk's Avatar
thanks
Pit shimizu 0571 and 0572 are good tires, and available from many online shops. That would be a good substitute for the TCS tires.
Old 09-07-2012, 07:32 AM   #411
I've got the servo moved all the way forward in the plastic servo mounts, with 2mm shims on the links
No noticeable bump steer
I probably should have more shim like your car, but the transponder is in the way
Your build looks good to me, just remember to keep at least 2mm of droop up front when adjusting ride height (by using the droop shims on the lower A-Arms)
Sometimes more is better, I've run 4+mm on low grip tracks to get the chassis to roll more
Old 09-07-2012, 09:40 AM   #412
JayL's Avatar
Thanks much sir! Cannot wait to try all your and robk's tips for my next big race:
http://www.rcfia.com/
check us out, I know you know the norcal boys
Old 09-07-2012, 02:45 PM   #413
gijoe64's Avatar
Trader Rating: 30 (100%+)
I'm selling my F104 Pro V2 never run with full aluminum read pod carbon rear top deck and savox shorty servo. I will post it with pictures tomorrow 300.00 firm.
Still have manual decal sheet. and stock rims.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 09-08-2012, 07:09 PM   #414
callender89's Avatar
Trader Rating: 33 (100%+)
I recently purchased and built a F104 the Ferrari edition. I was wondering what are the essential upgrades i need to make this thing race proof?
I have the aluminum motor mount, tamiya diff upgrade, and carbon rear shaft.
Southern California's only LOCAL DEDICATED FORUM
www.SOCAL-RC.com
callender89 is offline   Reply With Quote
Old 09-08-2012, 09:35 PM   #415
mtveten's Avatar
Trader Rating: 27 (100%+)
Put the stock rear axle back in, add the high traction t-bar and center shock. Turbuckkes for the front are also nice but not needed.
mtveten is offline   Reply With Quote
Old 09-10-2012, 06:37 PM   #416
Autocratic's Avatar
Trader Rating: 26 (100%+)
Just bought the V2. Wanting to know what hop-ups I need to go with this car before getting on track. Thanks.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 09-10-2012, 08:24 PM   #417
mtveten's Avatar
The aluminum pod plates are are the only must have hopup. tuning parts such as trailing axles, side spring set, center spring set are also good to get allowing you to dial the car in for any track. The trf center shock and springs make a nice lazy guy addition due to the through shocks frequent need for a rebuild.
Mark
Old 09-10-2012, 09:05 PM   #418
texastc's Avatar
Realistic liveries are fastest
Exotek F1Ultra Tamiya TRF101 SpeedPassion LM1 and SP1 and another Exotek F1Ultra on the way.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
TCdoesRC
texastc is offline   Reply With Quote
Old 09-10-2012, 09:08 PM   #419
Autocratic's Avatar
I need someone with the sticker hookup.
Old 09-10-2012, 09:36 PM   #420
texastc's Avatar
I happen to know somebody
TCdoesRC
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
