Old 09-02-2012, 03:31 PM   #376
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Team Repsol-Honda-Tamiya test session at TA Circuit
Courtesy of Velocity RC Mag
https://www.youtube.com/watch?v=nk1v...layer_embedded
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-02-2012, 03:40 PM   #377
Originally Posted by RedBullFiXX View Post
It was too much, just testing something that day
1 or 0 are the norm
Well, i like 2 degrees camber when I use my X1 with rubbers, at least best for me this way i think , always using 0571/0572 Shimizus rubbers. And 1 or 1,5 camber with foams. Maybe im wrong but i fell better this way with rubbers.
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 09-02-2012, 05:50 PM   #378
robk's Avatar
Trader Rating: 22 (100%+)
An X1 took the win at TCS Finals last week, narrowly edging out a VII
imo, the VII has more setting options for tuners that know how to get the most out of it, where as with the X1 you are always limited by a piece of flexing fibreglass, that will never be as consistent as dampers/springs
Both cars work well, though the X1 is easier to build, and slightly more durable depending on the t-bar you use
Totally right on. There were a lot of times I felt like I was working around things to get what I wanted out of the T bar F104. The VII made me happy the first day I drove it just because I could take an issue and work on it directly with the correct adjustment. Just the fact that the car can be set for tweak instead of chasing stressed t bars is calming to my nerves
Old 09-03-2012, 10:10 AM   #379
I drove my F104 PRO with 1 camber, gold springs at front and with the new TCS rubber tires and on power the car was less responsive with steering (isn't that oversteer?)
I need some more steering respons, so i will try 1.5 camber and perhaps with the silver springs or the front tires with full tire treathment (i always do half of the tire)
addicted2blue is offline   Reply With Quote
Old 09-03-2012, 10:30 AM   #380
robk's Avatar
Stiffen your center spring or make the shock more level. You have on power understeer. Going softer on the front end will make it crazy off power going into corners.
Old 09-03-2012, 10:32 AM   #381
Oversteer=crash into barrier rear end first
Understeer=crash into barrier front end first
Power=how fast you hit barrier
Torque=how far you move barrier when you hit
+ YouTube Video
Old 09-03-2012, 12:06 PM   #382
Center spring is the yellow one, i will try the blue one first and then try to level the center shock. Thx for advice.
Still learning about tuning the F104 as i haven't been that much busy with F1 cars.
Trying to get more practice with the F104 cars for next years tamiya season.
Old 09-03-2012, 12:08 PM   #383
+ YouTube Video
sidecarphil1 is offline   Reply With Quote
Old 09-04-2012, 08:43 AM   #384
I finally ordered myself last night a F104 PRO ver.II, very curious about it's performance, now i need a very good setup for an outdoor asphalt track with medium to good grip
Old 09-04-2012, 08:57 AM   #385
http://www.petitrc.com/reglages/tami...amiyaF104.html
http://www.petitrc.com/reglages/tami...ca20120630.pdf
www.rctech.net/forum/11009668-post240.html
Old 09-04-2012, 09:50 AM   #386
some questions about the setup from Fred Medel.
It says 1.5 toe angle front (is that toe out or toe in?)
It also says rebound stroke, how and where do i messure that?
And upright spacer is 4mm, is that above or under steering upright?
Also 1mm spacer between front camber plate and ball nut/ball connector, but what kind of 5mm ball thing did he use?
Did he use the steering servo in standard configuration or did he use a low profile servo with the nessacery spacers?
Old 09-04-2012, 10:59 AM   #387
JayL's Avatar
I am running FMW's tamiya track setup:
http://www.teamtrf.com/index.php/set...a-track-set-up
on my asphalt track and I need MORE entry steering, off power. mid and exit are pretty good. I ran the steel driveshaft only difference.
The rear is STUCK, I could hammer throttle everywhere, 21.5, so I am willing to give up some rear.
It was very stable easy to drive everywhere, just getting killed on entry. I tried crazy rear droop, no help.
571/572
help!
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 09-04-2012, 03:02 PM   #388
Toe Out
Read the VII info link in my sig, I think that will point you in the right direction, seems these questions are answered there
571/572
help!
Raise rear ride height, or even both front and rear to get the car to roll more
More front camber
Softer side springs, with less, or no pre-load (AE Black are a good option)
Which front uprights are you running, middle hole on alum uprights should help
Buggy grip on tires, full front if you really need that much
Contrary to some, imo a stiff car is less likely to carry corner speed, soften it up, and it will carve
Old 09-04-2012, 03:15 PM   #389
JayL's Avatar
More front camber
uprights: running alum middle hole, offset axle.
I tired buggy grip from half to full and paragon half to 3/4 not much difference and it wore off quick
I think the softer is my answer. I did not know which way to go(hard/soft)
I am also going to try the CF rear axle.
What do you think about .5 shim under upper front arm, rear?
Old 09-04-2012, 04:27 PM   #390
Something to try I guess, never felt balanced when i tried it
Inline axles will add some steering too
You may need to try some different tires, that's the biggest change, and most important
578 may free the back up some ?
What setup is killing you on entry ?
can you post a pic of your car ?
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
