Like Tree1Likes
Old 08-17-2012, 03:01 PM   #346
malcnz's Avatar
Originally Posted by LordAnubis View Post
Anyone know if parts will ever be available for this car? Obviously loooking for chassis parts as the rest in RM01 or F104. Looking for all the carbon parts that come in the kit (chassis, rear pod plate, the thing the side springs bolt into, and the top deck.
TQ Racing has all parts..I see some out of stock tho..how about Stella models they had when i brought off them a while ago now.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 08-17-2012, 03:22 PM   #347
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by bosfan View Post
The pitch spring controls the ride height of the chassis at the pivot, so it controls the chassis attitude. Some people run the car flat, with the pod and chassis level. Some run "sag" and let the car ride slightly lower at the pivot to let the pod "wind up" when the car accelerates. Don't run the car with the pivot area higher than the front and rear- not good. Starting off level is a good idea.
Also the stiffer the spring, the more on power steering you will have, at the expense of stability, especially in bumpy areas. A softer spring should turn a little more off power.
Old 08-17-2012, 06:48 PM   #348
Thank u just what I was looking for
bosfan is offline   Reply With Quote
Old 08-19-2012, 08:36 AM   #349
mikeygar's Avatar
Trader Rating: 14 (100%+)
Sharing the weight of my V2 in its race ready form.
IMG_0390.jpg by mikeygar2000, on Flickr
Orca 4500mah 60 C batt
Tekin RS ESC in brushed mode
Silver Can motor
all hopups avaiable for the V2 except rear carbon brace
standard F60 body with standard wings
If I were to add ballast weights to meet a minimum race weight, where would the best place to install weights be? I have my electronics inline with the battery so the original locations are available, are those okay?
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 08-19-2012, 10:08 AM   #350
it depends.... I personally move with battery on race, because changing the weight balance of car can change the driveability... it goes same for additional weight... it depends...
SquirrelCZE is offline   Reply With Quote
Old 08-19-2012, 07:06 PM   #351
Originally Posted by RedBullFiXX View Post
sag, pod & droop based on damper length of 68mm race ready
15k silicon, or Tamiya Hard damper lube
Tried your setup and I can't get the rear end to smoothly go around the sweeper.... It doesn't spinout but it kind of skips around and makes that erp erp erp noise any suggestions?
Old 08-20-2012, 04:25 PM   #352
Trader Rating: 43 (100%+)
i have a brand new tamiya f104 v2 for sale in box never opened.
F104 ( F 104) V2 ( VERSION 2 ) BRAND NEW
aceinthesky is offline   Reply With Quote
Old 08-20-2012, 07:33 PM   #353
Trader Rating: 6 (88%+)
Will this car take a hardpack lipo?
Ironwolf1974 is offline   Reply With Quote
Old 08-21-2012, 12:45 AM   #354
Yes.
Telinoz1975 is offline   Reply With Quote
Old 08-31-2012, 09:51 AM   #355
JayL's Avatar
My McLaren rear wing hits the rear cross tube on the alum motor mount. I also have the CF rear plate.
Should I space the wing back more or grind alittle of the wing where it hits or leave it?
Anyone else have this?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 08-31-2012, 10:03 AM   #356
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
If you are using the CF rear plate, make sure to mount wing with the included spacers
This will align the wing correctly
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-31-2012, 05:17 PM   #357
spring71's Avatar
Smile
RSector Rigid Rear System(RRS) for F104V2/RM-01 just came out.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 08-31-2012, 06:09 PM   #358
where can i read about setup tips on F104 v2? TIA
Minami is offline   Reply With Quote
Old 08-31-2012, 06:27 PM   #359
mikeygar's Avatar
http://www.petitrc.com/reglages/tami...amiyaF104.html
Old 08-31-2012, 10:22 PM   #360
Originally Posted by mikeygar View Post
ei mikey! thanks!~
might have to pass by JP today if i can to look at your car!
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
