Like Tree2Likes
Old 08-15-2012, 10:12 AM   #331
Trader Rating: 21 (100%+)
Originally Posted by Telinoz1975 View Post
I noticed there is a bit of space behind the rear wing when mounting onto the car, enough space for a red flashing LED (for that scale look).
Two options I see for this;
a) LED wired to car power supply
b) Small button battery module that is part of the wing, with small push button switch.
Anything off the shelf?
Anybody made their own that they want to share?
http://tqrcracing.com/shop/product_v...yword=&pg_no=1
http://tqrcracing.com/shop/product_v...pg_no=&bbs_no=
silencery is offline   Reply With Quote
Old 08-15-2012, 02:31 PM   #332
Originally Posted by RedBullFiXX View Post
I'm sure your shock is fine
The shaft stops in the cap and can go no further, this should provide more than enough range as the chassis will drag before the shock travel is used up
Here is a setup from a recent UF1 race on a very rough concrete surface
What was your chassis sag/rear droop, is the 15k diff oil?
bosfan is offline   Reply With Quote
Old 08-15-2012, 07:13 PM   #333
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by bosfan View Post
sag, pod & droop based on damper length of 68mm race ready
15k silicon, or Tamiya Hard damper lube
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-15-2012, 07:18 PM   #334
Old 08-16-2012, 04:15 AM   #335
What exactly does tightening or loosening the pitch spring do for the chassis does it control the bumpiness of the track or does it play another significant role ad well
Old 08-16-2012, 08:31 PM   #336
Csaari77's Avatar
Is there a trick to getting the TRF damper setup correctly on the V2? It seems like there is clearance issues using the damper with the cap toward the front. Any advice would be great.
How are people routing the servo wire when the reciever is mounted inline infront of the pod? I've been trying to figure out the cleanest way to do it, but I'm out of ideas.
Thanks!
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 08-16-2012, 10:53 PM   #337
Thanks!
Pg 13 in the manual
Forward shock mount position is different for TRF Shock
Old 08-17-2012, 05:31 AM   #338
Csaari77's Avatar
Pg 13 in the manual
I tried that and it seemed like I was getting an excessive amount of droop in the pod when the suspension was unloaded. Are you using spacers inside the shock to limit this?
Old 08-17-2012, 05:55 AM   #339
Yes
A few orings under the piston, then fine tune adjustment on shock end
Old 08-17-2012, 06:47 AM   #340
Csaari77's Avatar
Thanks for the help.
Old 08-17-2012, 07:30 AM   #341
np
Have Fun
Old 08-17-2012, 07:36 AM   #342
Csaari77's Avatar
I plan on it. This cars first run is going to be next Thursday at the Tamiya track. I'm bringing out my Pro and my V2, so even if I can't get the V2 figured out I'll still have a car that I know how to tune well.
Old 08-17-2012, 02:43 PM   #343
Trader Rating: 19 (100%+)
You definitely wont have any tuning problems with the V2. From all accounts (and my experience also) it seems to run great out of the box. The one thing you will have a problem with is the links breaking. Just don't crash.. or touch ANYTHING !!! Its a great car when it's running though, absolutely awesome.
LordAnubis is offline   Reply With Quote
Old 08-17-2012, 02:51 PM   #344
Anyone know if parts will ever be available for this car? Obviously loooking for chassis parts as the rest in RM01 or F104. Looking for all the carbon parts that come in the kit (chassis, rear pod plate, the thing the side springs bolt into, and the top deck.
Old 08-17-2012, 02:55 PM   #345
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
