Like Tree2Likes
Old 08-13-2012, 09:28 AM   #316
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by SquirrelCZE View Post
Hello
I just tested my own F104Pro Ver. II on our local track and it was.... PERFECT I was surprised how it was going out of the box....
anyway, there is one thing wondering me, It's alum servo mount... I've got the plastic one, but I just can't see a point in buying the alum one...
What's the difference between alum/plastic on track? Or to be correct, is it worth buying?
It's just for the extra bling, no performance difference
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-13-2012, 11:40 AM   #317
Originally Posted by RicerX1 View Post
Did you remember to drill the hole on the shock cap / top ball end?
Yes
bosfan is offline   Reply With Quote
Old 08-13-2012, 09:36 PM   #318
Originally Posted by bosfan View Post
Do your shocks compress all the way because mine do not did I do something wrong?
Old 08-13-2012, 09:42 PM   #319
Maybe you've overfilled the shock?
Old 08-14-2012, 03:12 AM   #320
Originally Posted by waswadener View Post
Du-Bro's Tru-Spin Prop Balancer PN 499 does a real nice job balancing F1 rears and other remote control car wheels.
F1 fronts rotate so freely on the car itself that the fronts can be balanced with the wheels on the car but fronts can also be balanced with the Du-Bro Tru-Spin.
Thanks!
Telinoz1975 is offline   Reply With Quote
Old 08-14-2012, 03:53 AM   #321
what bodies and wings do you guys usually use for the races? and please post description of each if you can.
Minami is offline   Reply With Quote
Old 08-14-2012, 06:54 AM   #322
The shaft seems like it's too long it bottoms out before it goes all the way into the body
Old 08-14-2012, 05:07 PM   #323
Any setups for a asphalt bumpy track with with 3 180 turns one of them really tight plus gearing suggestions for a 21.5 brushless
Old 08-14-2012, 06:23 PM   #324
I'm sure your shock is fine
The shaft stops in the cap and can go no further, this should provide more than enough range as the chassis will drag before the shock travel is used up
Here is a setup from a recent UF1 race on a very rough concrete surface
Old 08-14-2012, 06:26 PM   #325
Trader Rating: 43 (100%+)
Does the kit come with rims if so wich ones
aceinthesky is offline   Reply With Quote
Old 08-14-2012, 06:38 PM   #326
This is the kit
Check the VII link in my sig for answers to lots of questions you may have
Old 08-15-2012, 12:49 AM   #327
I noticed there is a bit of space behind the rear wing when mounting onto the car, enough space for a red flashing LED (for that scale look).
Two options I see for this;
a) LED wired to car power supply
b) Small button battery module that is part of the wing, with small push button switch.
Anything off the shelf?
Anybody made their own that they want to share?
Old 08-15-2012, 02:01 AM   #328
One other thing, I went for the 53901 TRF Special damper.
It comes with a White spring which I think is Medium?
Are there other spring options for Soft, Hard?
Or do you just have the option of oil type for this?
My best 'guess' is this set - p/n: 84117:
http://www.stellamodels.com.hk/84117...te-p-4859.html
Old 08-15-2012, 02:22 AM   #329
Pro10noob's Avatar
If i am not mistaken, there should be a colorcoding on the spring.
Like red,yellow,blue or none.
It is a small dot on the end of the spring.
It is the same as the normall colored springs.
Oil i would start with if you use Tamiya,300 and work your way from there.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-15-2012, 04:40 AM   #330
malcnz's Avatar
this is the spring set I got:
http://www.stellamodels.com.hk/53163...ly-p-4590.html
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
