Like Tree2Likes
Old 08-06-2012, 08:02 PM   #301
Well the ones for the "current" BMI car are shorter than the AE link but the current prototype uses links that are the same length. As the car is still in prototype I'm not sure yet if they are selling the new links yet. Sorry can't find where my pics are right now.
Old 08-06-2012, 08:58 PM   #302
ogreasurada's Avatar
Originally Posted by RicerX1 View Post
It's to create a vent hole for when the shock shaft goes into the cap it doesn't create necessary pressure and increase damping rate. So when you compress the shock, the shaft wont rebound (w/o a spring). (poor explanation but its the best I could do with my limited knowledge)
I was wondering about rebound after shock assembly, guess I got it right then, thanks a lot.
ogreasurada is offline   Reply With Quote
Old 08-08-2012, 08:38 PM   #303
Csaari77's Avatar
Trader Rating: 34 (100%+)
I'm in the process of building my V2 and I need some help with the aluminum uprights. They are much thinner than the stock pieces and the spacers and uprights don't snug up inside the arms. How are you guys assembling them? Are you adding spacers, or are you just locking the upright against spacers and the top of the arms?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 08-08-2012, 09:00 PM   #304
Trader Rating: 45 (100%+)
Send a message via AIM to RicerX1
Tamiya F104 Version 2
RicerX1 is offline   Reply With Quote
Old 08-08-2012, 09:57 PM   #305
Source: http://takatakanokkey.blogspot.com
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 08-08-2012, 10:02 PM   #306
Csaari77's Avatar
Thanks for the quick reply. I figured it was already posted somewhere, but I can't use search from my phone.
Old 08-11-2012, 09:01 PM   #307
11 August 2012 - My friend Taka finally decided to test his new Tamiya F104 version 2 against his already very fast Tamiya F104 t-bar car.
Full review here.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
Old 08-11-2012, 09:17 PM   #308
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Full review here.
thank you sir.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 08-12-2012, 04:44 AM   #309
I'm about 70% through my build of the F104 V2 kit + the upgrades as per the Tamiya USA guide (which has been great, the low profile servo is the way to go).
I hate tierods!!
I did it the hard way (hand + pliers = pain) as I don't have the right tools (on order now for next kit build). Whinge over...
I'm also building a Xray T3 2012 kit, already got a Hudy 1/10 wheel balancer for the touring wheels.
Now, I've had a look for wheel balancer adaptors for these F1 cars and can't seem to find anything.
I guess it doesn't help when the Front wheels fit over 2 bearings the Rear wheels are over 14mm Hex nut size!
Has anyone found/made a wheel balancer for Tamiya wheels/TRG wheels?
At the moment, I'm thinking about hacking a front upright (I have the adjustable ones, so may use the plastic kit one) and then putting a 4mm thread so it fits onto Hudy unit.
For the rears maybe a 4mm spacer/thread 14mm Hex custom job to extend off the Hudy 4mm thread.
Both require some thought and time to make, so looking for options before I spend a few hours on this.
Telinoz1975 is offline   Reply With Quote
Old 08-12-2012, 07:28 PM   #310
How do you adjust the rear droop
bosfan is offline   Reply With Quote
Old 08-12-2012, 08:18 PM   #311
BadSign's Avatar
Trader Rating: 15 (100%+)
lengthen or shorten the main shock shaft by tightening or loosening the adjuster. Shorter shaft, less droop. longer shaft, more droop.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 08-12-2012, 09:08 PM   #312
Trader Rating: 72 (100%+)
Du-Bro's Tru-Spin Prop Balancer PN 499 does a real nice job balancing F1 rears and other remote control car wheels.
F1 fronts rotate so freely on the car itself that the fronts can be balanced with the wheels on the car but fronts can also be balanced with the Du-Bro Tru-Spin.
waswadener is offline   Reply With Quote
Old 08-13-2012, 12:36 AM   #313
Hello
I just tested my own F104Pro Ver. II on our local track and it was.... PERFECT I was surprised how it was going out of the box....
anyway, there is one thing wondering me, It's alum servo mount... I've got the plastic one, but I just can't see a point in buying the alum one...
What's the difference between alum/plastic on track? Or to be correct, is it worth buying?
SquirrelCZE is offline   Reply With Quote
Old 08-13-2012, 09:01 AM   #314
Do your shocks compress all the way because mine do not did I do something wrong?
Old 08-13-2012, 09:06 AM   #315
Did you remember to drill the hole on the shock cap / top ball end?
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
