Old 07-26-2012, 11:37 AM   #256
wiggindude6969's Avatar
Originally Posted by RedBullFiXX View Post
Heavy side springs actually offer less corner speed, with more stability
If you want the car to turn in hard, try less pre-load on side springs, 1 or 2 turns out from touching the pod plate will make the car very aggressive
Side springs just touching is a good baseline
Match roll damper to springs, heavier damping, slower roll, too heavy and inside wheel lift can occur
Read up on some 12th scale articles for more info on tuning a link car
And make sure the pod is built with no bind at all
To check this, remove motor and all upper pod sections
Lower pod plate with links should be free of any tension, just like a damper has to be free on it's pivot, same deal
i have the exotek front end on the car and the Caster seems to have moved from 0 to about +3 deg. I am going to change this to -1 deg and with the battery moved forward try it like this... then adjust the side springs and damper oil. i have to find a starting point that I can work with..
Thanks for the tips.
F104v2 - RSD/TC6.1 - CRCXTi - AE B6
wiggindude6969 is offline   Reply With Quote
Old 07-26-2012, 01:45 PM   #257
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by malcnz View Post
Took my v2 out today for some practise with the new pit 571 and 575 combo for low grip as winter here.
Found i had good rear grip but it still under steers into corners compared to the foam tyres I have tryed(tamya soft rear, hard front) but has way more rear grip and wondering what I could try to get some more steering into the corner and get rid of the push?
thanks.
571, 572 will take away some rear grip, could be a better balance for your track
Also, try softer side springs with no tension
Ride height 5mmF, 6mmR, raise it up more if the chassis is dragging over bumps
Lower if it's a smooth track
Adding rear droop should give the car more corner entry speed, at the expense of stability
Softer front springs, with at least 2mm droop should help
Just some basics for tuning...
I've yet to see rubber tires match corner speed of foam tires
That will be an uphill battle
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-26-2012, 02:44 PM   #258
malcnz's Avatar
cheers for that..do have a bit of tension on the side springs so will change that and have a look at other stuff you mention.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 07-30-2012, 12:22 PM   #259
JayL's Avatar
Yes and Yes
btw, there is no need to add spacers under the uprights, they serve no purpose, and can cause the pivot ball to pop-out on the lower A-arm during a hard impact
just make sure to have the droop screws adjusted correctly
Can you elaborate alittle on the front spacers?
If I don't run spacers under the upright do I run them above the arm or just leave them in the box and allow freeplay on the front end?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 07-30-2012, 01:38 PM   #260
When using the Aluminum Uprights
Run spacers on top of the upright to set ride height
Pull upright towards upper a-arm, and tighten grub screw on upright, this will remove any freeplay between the upright and a-arm for a consistent setup
Use shims to adjust droop on the lower a-arm droop screws
Note pic below for reference
See the VII link in my sig, all is explained there
I recommend the "off-set" axle setup, in most conditions this will be the most balanced
Old 07-30-2012, 09:25 PM   #261
Trader Rating: 15 (100%+)
Default King pin
Does anybody know of a longer kingpin like 3m x 36 mm.
AARON YOUNG is offline   Reply With Quote
Old 07-31-2012, 07:57 AM   #262
Is that your spring under the upright or is it under the lower arm
bosfan is offline   Reply With Quote
Old 07-31-2012, 08:30 AM   #263
Spring is under a-arm
Old 07-31-2012, 06:10 PM   #264
malcnz's Avatar
30wt in TRF shock is close to 900wt on kit aluminum shock
just got a trf shock to try and is 30wt with the 2 or 3 hole piston?
also got the springs and red best for low grip?
cheers.
Old 07-31-2012, 07:13 PM   #265
Default Side links
What if any changes does it make if you space the side links up on the chassis or on the pod? Does it work to change rear grip like on a full size car ?
Old 07-31-2012, 10:08 PM   #266
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Hey guys, nearing completion of my V2. So for the 1mm hole in the damper cap, how far should I drill it? Halfway? Or completely the way thru?
Dan is offline   Reply With Quote
Old 07-31-2012, 10:17 PM   #267
malcnz's Avatar
Halfway
Old 08-01-2012, 10:14 AM   #268
Default Rear Pod hitting the set screws on the bottom deck
Are you guys having this issue too... it was pointed out to me this weekend... the side damper with the stock set up.. the 10mm set screws that hold the side screws on... hit the side damper. I dont have the shorter set screws yet... so i cant fix it on my car... I also noticed that the side "plastic" parts have a slight bow in them... i took the car apart, made sure i built it to the book and they flattend out, after a day or practice they are slightly warped again... i ordered the RM-01 side parts (2)sets and i am going to replace them when the parts come in...
Took your advice and went with silver front springs and the 2mm droop... I am mounting another new set of Pitz tomorrow, when i got my tires from TQ... i built 2 complete sets of med fronts and soft fronts and i might have labeled them wrong... so im just gonna build new ones... so there is no question....
Old 08-01-2012, 03:53 PM   #269
JayL's Avatar
My side damper hits the set screw for the side spring as well. I am going to try a 5mm set screw instead of the 10mm
for the side links I am switching to the AE RC12L5 ones and the AE pivot balls they go on.
Old 08-02-2012, 07:00 AM   #270
Originally Posted by Thunderbunny View Post
Finally finished! Now it's time to mount the electronics.
Looks like an X1 ver.II
Really looks great, i like it a lot.
addicted2blue is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
SEO by vBSEO 3.5.0
