Like Tree2Likes
Old 07-22-2012, 07:28 AM   #226
Just finished a club race. Of the 3 F104 v2 drivers, one was absent, the other fast driver switched back to his WGP because the link suspension was to fragile resulting in a lot of DNF. The third driver also had broken suspension issues.
Verdict so far on our track is that the tune ability is good but it is also easy to get out of tune and fragile.
Will see how they fare in the next race.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 07-22-2012, 01:07 PM   #227
Dropsomegears's Avatar
Default Wow
Took out the PRO 2 yesterday and it was fun. The setup sheet for Tamiya is a good starting point but def too low for parking lot racing lol. I may be jynxing myself but I thought the car is pretty solid. I was bouncing off of plow discs rolling down the strait etc. I chipped my front wing and that was the most of it. Cant wait to run again.
Oh and Thanks Robk Yeah I was overthinking the rear height linkage lol.
Ben.
F104 Pro V2,TA05 VDF, TB-03
SGT *USMC*
"I do not agree with a word that you say, but I will defend to the death your right to say it"
Dropsomegears is offline   Reply With Quote
Old 07-22-2012, 09:42 PM   #228
Trader Rating: 15 (100%+)
Default Chatter
What are some of the ways to get rid of front end chatter? And are the majority of fast guys running shorty or full size packs?
AARON YOUNG is offline   Reply With Quote
Old 07-22-2012, 09:45 PM   #229
racer x 1's Avatar
Trader Rating: 27 (100%+)
Short packs. All elecs inline. As far as the chatter ive heard you can use a light diff oil on the front kingpin for "damping" action to aid.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 07-22-2012, 11:03 PM   #230
Anybody thrown a 103 front end on their v2 yet?
J-PaP is offline   Reply With Quote
Old 07-23-2012, 03:43 AM   #231
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Shorty pack. I use a little Tamiya AW grease on the pins.
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 07-23-2012, 07:18 AM   #232
texastc's Avatar
Just switched to a shorty pack. I love it. I'm selling my full size packs.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 07-23-2012, 09:17 AM   #233
wiggindude6969's Avatar
I have the same issue with the side springs poping off... so i glued them the last run after i lost the left side black sping and one gold spring... i had 2 sets of gold springs or i woulda been out this weekend.... since then, one of the local racers told me that he is using the CRC alum holders and springs.. they are on A main hobbies. He is using them and they have not came off yet. I need to find a way to get more steering. I am using 1000 wt in my side damper, 50 in the center, with hard rear springs and med front springs.. and i cant get my rear end to break loose unless i slam on the breaks and turn the wheel.... This week i am going to move the battery up to the front.. i have about 1/4" more i can move it and then double check the front tires to make sure they are soft... i coulda built them and marked them wrong... i built softs and med fronts and hard rears all at the same time...
F104v2 - RSD/TC6.1 - CRCXTi - AE B6
wiggindude6969 is offline   Reply With Quote
Old 07-23-2012, 10:50 AM   #234
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Heavy side springs actually offer less corner speed, with more stability
If you want the car to turn in hard, try less pre-load on side springs, 1 or 2 turns out from touching the pod plate will make the car very aggressive
Side springs just touching is a good baseline
Match roll damper to springs, heavier damping, slower roll, too heavy and inside wheel lift can occur
Read up on some 12th scale articles for more info on tuning a link car
And make sure the pod is built with no bind at all
To check this, remove motor and all upper pod sections
Lower pod plate with links should be free of any tension, just like a damper has to be free on it's pivot, same deal
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-23-2012, 01:44 PM   #235
JayL's Avatar
on the v.2 setup sheet it has:
"Upright spacer": is that the amount of shims ABOVE the front upright?
also
"Rebound stroke": is that front end droop, lke mentioned in the tamiya usa article?
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 07-23-2012, 01:48 PM   #236
also
Yes and Yes
btw, there is no need to add spacers under the uprights, they serve no purpose, and can cause the pivot ball to pop-out on the lower A-arm during a hard impact
just make sure to have the droop screws adjusted correctly
Old 07-23-2012, 02:25 PM   #237
robk's Avatar
Trader Rating: 22 (100%+)
+ YouTube Video
Old 07-23-2012, 03:18 PM   #238
JayL's Avatar
ok, next question:
I am going to run the regular TRF center shock, what oil would respond like #900 in the kit v.2 center shock
Old 07-23-2012, 03:31 PM   #239
ok, next question:
30wt in TRF shock is close to 900wt on kit aluminum shock
Old 07-23-2012, 07:21 PM   #240
Thumbs up
Originally Posted by robk View Post
+ YouTube Video
Well done Rob !
That's bout as in depth as you can get on setting the football
This is THE main factor to proper link car assembly
The center pivot ball free play is also adjustable, this should be free, with as little play as possible
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
