Old 01-14-2015, 12:54 PM   #1711
Originally Posted by scirocco14 View Post
Did you move the front damper mount to its rearward position, per the manual if using the special damper?
Mark
Yes. At first I thought I had to have it in the more forward position due to the sag, but it will not fit correctly due to the size of the shock.
Enjoying this rc hobby while I can!
teknorookie is offline   Reply With Quote
Old 01-14-2015, 01:41 PM   #1712
For the TRF damper on the F104, I usually use Tamiya's shorter springs and still have plenty of adjustment for preload. Tamiya #s 53333, 53630-53633.
viking44 is offline   Reply With Quote
Old 01-14-2015, 02:43 PM   #1713
I would have guessed they were both the same size. Had it in my cart them decided last minute, I try as is.
Any issue running it with preload ?
Old 01-26-2015, 01:32 PM   #1714
Robby368's Avatar
Hey folks, I'm new to the F1 world. Just picked this up on ebay, hopefully it will be in tomorrow. Did I get a good deal?
Tamiya F104V2
Before you judge someone, walk a mile in their shoes. Then you'll be a mile away and have their shoes.
Robby368 is offline   Reply With Quote
Old 01-26-2015, 01:37 PM   #1715
Pro10noob's Avatar
Naise
Only the 3racing shock is a bit odd.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-26-2015, 02:01 PM   #1716
Tamiya F104V2
Sounds like a reasonably good deal. Not a steal, but you got a nice package for the price.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 01-26-2015, 03:34 PM   #1717
Trader Rating: 24 (100%+)
Tamiya F104V2
Looks like a fairly good deal to me, car already setup well.
Have fun, F1 is a blast to drive!
Xray T4 | Tamiya F104v2
http://youtube.com/c/jmetznet | * YouTube Race Videos, Build videos, and more *
justinco is offline   Reply With Quote
Old 01-26-2015, 06:32 PM   #1718
stock f104 is skipping under acceleration. any clues to solve it?
fuse01 is offline   Reply With Quote
Old 01-26-2015, 07:09 PM   #1719
Trez83's Avatar
My F104 unloads its rear inside tire on every 180 turn at our local carpet track. I have it set up soft right now because it just feels more stable and controllable.
What's the first adjustment I should try?
Heavier pitch springs or thicker roll damper grease? Put the medium springs in the front?Really tighten the diff?
I just need to correct this issue. The rest of the car is great.
Thanks!
Trez83 is offline   Reply With Quote
Old 03-26-2015, 09:57 AM   #1720
Cadman1981's Avatar
Anyone have tips for Trez83? I have the same issue. I was thinking of putting AW grease in the Diff to help when the rear lifts and the car diffs out
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 03-26-2015, 10:08 AM   #1721
scirocco14's Avatar
I've tried that and it will make the car spin out under power if you put too much. The AW grease is VERY sticky.
The better solution is to figure out WHY the rear is lifting. 1st place to check is the roll damper. Go to a softer oil or grease and see if that helps. A quick check is to take it off and run it without it for a few laps and see if makes a difference.
Mark
Mark C. USVTA #115 TC4 & TC5, USGT #115 Xray T4 '13
USVTA-F1 #115 F1R & F1R3
Bush River RC, The RUG at King, Ho B Max Raceway
scirocco14 is offline   Reply With Quote
Old 03-26-2015, 12:06 PM   #1722
Thanks!
Is it coming of the ground? I would go softer on the roll damper.
napoleon1981 is offline   Reply With Quote
Old 03-26-2015, 12:34 PM   #1723
wtcc's Avatar
Also check if your side springs are touching the chassis. If so make sure they are not under tension, but barely touching the chassis with the car standing on your setup board.
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 05-17-2015, 05:04 PM   #1724
I'm looking at buying an F1 and have two available to me. A lightly used V2 with lots of upgrades and the Exotek front end. Or a NIB TRF101. The V2 is significantly cheaper. Racing would be foam tyres on carpet or rubber tyres on bitumen. Any comments to help with my choice?
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 05-17-2015, 05:09 PM   #1725
The TRF101 sure is a nice F1 car, but the V2 can be just as nice especially if it is upgraded. I have a V2 and never felt the need to "upgrade" to the TRF101. If the price is right I would think the V2 would be great, of course I am slightly biased because that is what I drive
I have a bunch of build and racing videos of my V2 if it helps with your decision.
+ YouTube Video
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
