Like Tree1Likes
Old 07-27-2014, 06:54 PM   #1681
mtveten's Avatar
Trader Rating: 27 (100%+)
lengthen the center shock, a little more up travel will increase the forward weight transfer increasing off power steering. reducing the brake power and/or raising the front end can also help if the nose is bottoming out.
mtveten is offline   Reply With Quote
Old 07-28-2014, 03:20 PM   #1682
robk's Avatar
Trader Rating: 22 (100%+)
Stiffer side dampening will reduce rotation until the car starts to slide.
By spring do you mean side spring or center spring?
Stiffer center spring is usually more on power steering, though it can kind of make the rear end feel locked up mid corner on a link car.
Stiffer side spring is kind of like the dampening, though most of the time it makes the car feel more stable rather than making it slide. A softer side spring can make the car rotate more, but if you are too soft the car will wander or not feel like it tracks straight.
Old 07-28-2014, 07:02 PM   #1683
Pauly6401's Avatar
Trader Rating: 41 (100%+)
Does anyone have tricks on how to screw on the damper caps without cross threading them? I've tried to line them up as carefully as possible and thread them in gently without too much pressure, and no matter what they either start wobbling or get bound up. It's infuriating - even more so than the tiny e-clips used on the shock shafts!
I plan on swapping them out with the touring car dampers at some point, but right now I would just like to finish building the kit. Whoever thought soft plastic and metal would work well with threads that fine wasn't thinking.
Losi XXX-T CR * Traxxas Revo Tekno Brushless Conversion * Losi 8ight 2.0 * Losi 8ight-E 2.0 * Corally RDX * HPI Blitz * Tamiya F104 V2 Pro * Associated TC 6.2
Pauly6401 is offline   Reply With Quote
Old 07-29-2014, 08:53 AM   #1684
tdu verney's Avatar
Default Asphalt Shock Preference
Is there a center shock preference for running on asphalt big (TC) vs. small (12th scale)?
tdu verney is offline   Reply With Quote
Old 07-29-2014, 08:49 PM   #1685
Photocycler's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Pro10noob View Post
Yeah
He means the one piece thrust bearing you put in the dif instead of the original ballbearing.
It gives you a way smoother diff.
Don't forget the put the springwashers like this---> )( instead of what manuals says -----> ()
The one piece trustbearing was or better yet is a hopup for the f103 rearaxle and wurth the investment.
Regards Roy
During my maiden runs, the diff kept coming loose. I tightened it up more then I would like and wondering if I should be running the spring washers like )( instead of how the manual states ()
Photocycler is offline   Reply With Quote
Old 07-31-2014, 10:40 PM   #1686
Ok so my pushing and off power steering issues have been somewhat resolved. Car is driving much better...couple things I did-went to 2 degree camber, 2 degree toe.
Now I am noticing my back end isn't having as much traction on straights and wide turns as it did...seems to slide more. What can I do to help resolve that?
Old 08-13-2014, 06:29 PM   #1687
waltss2k's Avatar
I have a question, I have a F 104 that has a lot of Hop Ups on it and was wandering about is the Exotek #1205 Adjustable Arm set worth the buy and how much will it help the car.
waltss2k is offline   Reply With Quote
Old 08-13-2014, 08:13 PM   #1688
kerry's Avatar
Think it only works on the exotek f1r conversion kit
kerry is online now   Reply With Quote
Old 08-13-2014, 08:19 PM   #1689
robk's Avatar
It is worth every penny. Adjustable caster and camber makes the car much more tunable..works on all 104 front ends
Old 08-13-2014, 09:00 PM   #1690
tdu verney's Avatar
Is there a preference to caster and camber over the stock front end?
Old 08-13-2014, 09:17 PM   #1691
kerry's Avatar
Thanks I was thinking the ifs coming out from exotek
Old 08-14-2014, 03:52 AM   #1692
waltss2k's Avatar
Ok. Cool thanks Rob.
Old 08-15-2014, 01:25 PM   #1693
waltss2k's Avatar
Going to test out my new Exotek front end on my F 104 tonight.
Old 08-19-2014, 09:02 PM   #1694
So after a solid of dialing in the car and not breaking any parts...I stripped a spur gear on a light impact.
I went ahead and put in new spur gear and now when I get on the throtttle I hear a high pitch grinding noise which sounds like a spur stripping—but it doesnt look to be stripping the spur. I am thinking maybe the rear plastic chassis is comprised somehow—I checked for cracks but not seeing anything.
In the stand when I punch the throttle I hear the same thing and see the motor kinda twisting back. anyone have this issue before?
[evan b]
Timezone I & II | RoseCityScaleRacing | Premier RC Raceway
Old 08-21-2014, 03:21 PM   #1695
Norman2's Avatar
The best mod you can do to improve handling balance is the 3R racing Adjustable Camber mount at half the price of the Exotek system. You can Change camber 0,1,2,or 3 degrees very easily and will fix any front end
handling problem. It is like night and day. See photo attached. Regards
Norman2
Norman2 is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9352 04-22-2017 06:01 AM
