Old 07-19-2014, 07:52 AM   #1666
Photocycler's Avatar
Trader Rating: 33 (100%+)
Originally Posted by terry.sc View Post
The kit spur is 0.4 module, not 64dp. To fit a standard spur gear you need the Tamiya spur gear spacer http://www.tqrcracing.com/shop/produ...w.asp?p_id=881
Can I run a normal 64p pinion with the stock spur?
Photocycler is offline   Reply With Quote
Old 07-19-2014, 09:52 AM   #1667
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
Yes, it will work. Just a little noisier.
Dan is offline   Reply With Quote
Old 07-19-2014, 10:00 AM   #1668
64dp is the equivalent of 0.395 module, so close enough to get them to mesh together but they will be noisy and the spur gear won't last long.
terry.sc is offline   Reply With Quote
Old 07-20-2014, 11:26 AM   #1669
What did u guys use to loosen up the balls in the front upper arms?
Mine are not as loose as needed?
Also, I will be running on a medium sized medium grip carpet track. I plan to run the stock spring and #350 shock oil in the shock, what should I use in the dampener?
Old 07-21-2014, 05:04 AM   #1670
Trader Rating: 21 (100%+)
What I do is this. I use a very sharp hobby knife and run it inside of the holes to cut excess plastic flashing off. Then use some fine grit sandpaper "600". Roll it tight enough to get into the holes. Use alcohol or some kind of cleaning liquid. If you want. You could go even further and use a dab of Tamiya anti wear grease, red or black Team Associated grease in the holes.
RS_ZACH is offline   Reply With Quote
Old 07-22-2014, 05:40 PM   #1671
Looking for tips to mount a low profile servo. How do you affix the servo to the chassis?
Old 07-22-2014, 06:03 PM   #1672
RCBuddha's Avatar
Servo Tape, and the servo standing up like the picture.
RCBuddha is offline   Reply With Quote
Old 07-23-2014, 09:20 PM   #1673
Ok got the car together, pretty tough wiring it up with my large orca esc and capacitor. Will be switching to a hobbywing for a smaller footprint.
Question on sensor wires, are you guys running them, seems to make it even tighter in back with the sensor wires and i do not want ti disrupt the pod.
Old 07-23-2014, 09:31 PM   #1674
robk's Avatar
Trader Rating: 22 (100%+)
Ball end reamer in the upper arms....available from any number of manufacturers
TQ Wire makes super flexible sensor wires in various lengths. CRC has them as well.
Old 07-23-2014, 10:58 PM   #1675
Thx for the help, the car is together minus the side pods and induction vent which I will add tomorrow.
Build was pretty easy but the body is tedious. The wiring is tricky, had to use a RX from another car but the RX for this car will not have a wire
Old 07-24-2014, 11:13 PM   #1676
Ran the car tonight, it was a blast
Right now the car is pushing off power. I am using the stock kit spring (gold) and 350 wt oil in both dampers. What can i do to get more off power steering and not have it push. Im running about 1.5 toe out, 1" camber and about a 4.5 ride height
Im running Pit tires with sauce and I feel pretty confident its not the issue.
Old 07-25-2014, 12:23 AM   #1677
robk's Avatar
increase shock length for more rear droop
Old 07-26-2014, 05:07 PM   #1678
BadSign's Avatar
Trader Rating: 15 (100%+)
You can also try thicker lube. 5K, 10K.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 07-26-2014, 06:54 PM   #1679
Also you can put more camber in it try 1.5 or 2.0 this will help turning in off power
Trav515 is offline   Reply With Quote
Old 07-26-2014, 07:02 PM   #1680
I swapped out the side dampener which was a shock with 350wt oil for the tamiya he'd dampener and used 30,000 grease. Gonna give that a try and may also reduce the spacer under the other dampener. Wondering if adding a stiffer spring would help much since I'm one away from the hardest tamiya?
Adding camber sounds good also
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
