Old 05-28-2014, 09:52 AM   #1651
Cadman1981's Avatar
Originally Posted by libra26th View Post
Excuse me I have a question. I have servo savox sc1258tg. Can I use it without cutting servo mount.
You have to cut the mount for it to fit, no choice...
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 06-04-2014, 04:43 PM   #1652
Send a message via MSN to rnelias Send a message via Skype™ to rnelias
rnelias is offline   Reply With Quote
Old 06-04-2014, 06:56 PM   #1653
You don't need to cut the tabs if mounting the servo horizontally
J-PaP is offline   Reply With Quote
Old 06-04-2014, 08:48 PM   #1654
Cadman1981's Avatar
When i put my servo horizontally, the tabs were in the way of the servo arm and ballstuds
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 06-04-2014, 09:34 PM   #1655
kzsteve's Avatar
Default F-1 model id
i have an older F-1 rc car . but it is huge . how do i tell what model it is ?
pic attached . the car is 4' long .......... thanks .. steve
kzsteve is offline   Reply With Quote
Old 06-04-2014, 09:44 PM   #1656
Wasn't an issue when using the savox 1251mg. I do remember using some spacers on the steering hub to make the arms sit horizontal.
Old 06-05-2014, 01:44 PM   #1657
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
If anyone is interested. I have a very nice f104v2 for sale
For sale link: http://www.rctech.net/forum/r-c-item...-pictures.html
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 06-11-2014, 11:12 AM   #1658
Looking for a good baseline setup for a loose asphalt track any input will help
Thanks Travis
Trav515 is offline   Reply With Quote
Old 07-15-2014, 10:40 PM   #1659
Photocycler's Avatar
Trader Rating: 33 (100%+)
Just bought the F104 v2 kit, wondering what servo would be good for a new F1 driver? Would prefer to not spend a lot of $$
Photocycler is offline   Reply With Quote
Old 07-15-2014, 11:56 PM   #1660
wtcc's Avatar
Go for the Savox SC-1252MG; good price and perfect size.
@ Trav515: try silver springs in front and the soft pig skin coloured springs in the rear for the big damper and the side springs together with the kit oil. If its still loose try harder springs in front and tire additive for the rear tires only.
AE / Reedy / RSD
wtcc is online now   Reply With Quote
Old 07-16-2014, 10:40 PM   #1661
Do a search for 1/5 scale f1 or post a picture of the chassis
ic-racer is offline   Reply With Quote
Old 07-18-2014, 03:31 PM   #1662
Fran's Avatar
Trader Rating: 132 (100%+)
I just bought and built a F104V2 last month and I'm getting back into r/c racing after a 4 year absence. What a blast! I've gone back and read all 110 previous pages to read up on my new ride, and I have a few questions that I hope haven't been answered. Our club, The Roadrunners have a outside asphalt track, and the grip is medium plus, as long as the wind doesn't blow the dirt from the farm fields that surround the track.
When installing the thrust bearing in the diff, is it run dry, or do you put a little grease in it? When installing the optional metal uprights, I know to push them up against the spacers and tighten set screw. What front droop do I then want to set for our track? I put the optional TRF damper in the rear and spaced the piston shaft for 3.5 rear droop.
From what I've read, the less the traction, the "softer you make your car", right?
We've got some really good racers that come up and race with us, and they've been helpful. It's just 2 weeks between races, and I want to be ready on race day (next Sunday) Many thanks to those who support this thread and contribute!
Fran is online now   Reply With Quote
Old 07-19-2014, 01:30 AM   #1663
QUestion: Is the stock spur gear that comes with the kit a 64p? If not can I replace it with any spur gear or do I need an adapter or special spur
Old 07-19-2014, 02:06 AM   #1664
The thrust bearing needs some grease.
Tamiya typically has a metric pitch spur. You need a small adapter ring for 64p spur gears. So, either run Tamiya-size spurs and pinions, or run a 64p spur and pinion with an adapter.
Tamiya TRF101, Corally F1 SL, 3Racing F1-09, Kyosho Mini-Z MR03, Corally SP12M, Tamiya SuperShot, Kyosho Optima Pro, Duratrax Vendetta.
Home track: http://www.amcaracing.nl
ijdod is offline   Reply With Quote
Old 07-19-2014, 04:56 AM   #1665
The kit spur is 0.4 module, not 64dp. To fit a standard spur gear you need the Tamiya spur gear spacer http://www.tqrcracing.com/shop/produ...w.asp?p_id=881
terry.sc is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
