Old 03-01-2014, 02:40 PM   #1621
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Pro10noob View Post
Now you telling me???
Just bought me one
Regards Roy
Hi Roy,
Fell free to PM me for set up tips
M
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 03-01-2014, 03:01 PM   #1622
Pro10noob's Avatar
LOL@Yogi... No worries about the setup
Running it 200MM foam with a 90ties body
Just got it in and now looking for the front spoiler to go with the RM body.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-04-2014, 07:09 AM   #1623
Cadman1981's Avatar
Some pretty whicked pictures from www.f1italianseries.it
I saw these on their facebook page - https://www.facebook.com/F1italianseries
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 03-07-2014, 12:24 PM   #1624
IlikeF1's Avatar
Hi Everyone,
I am building my first RC F1 - an F104V2.
I am mounting a low profile servo but have a question about the ball studs. On Tamiya's website it describes this option and says that:
"The only thing one must do is add 4mm of spacing to the steering linkage ball connector attached to the servo horn. Tamiya item 53539 is the perfect spacer set for this application."
I have ordered the spacer set but then realized that the ball stud shafts won't be long enough to put a 4mm spacer on and still attach the nut.
Can anyone tell me if there is a long shaft ball stud I need to use - and the part number if available?
Is the spacer absolutly necessary?
I would be interested to hear what other have done, since it seems like most use the LP servo option.
Sorry if this has been covered but I searched for hours with no luck!
Thanks in advance!
IlikeF1 is offline   Reply With Quote
Old 03-07-2014, 12:49 PM   #1625
Trader Rating: 35 (100%+)
You need the 5x8mm ball stud like this:
http://www.tqrcracing.com/shop/produ...w.asp?p_id=912
Adding shim is not absolutely needed. It's more of a tuning thing.
Originally Posted by IlikeF1 View Post
Hi Everyone,
Thanks in advance!
v_squared is offline   Reply With Quote
Old 03-07-2014, 01:06 PM   #1626
Csaari77's Avatar
Trader Rating: 34 (100%+)
Hi Everyone,
Thanks in advance!
You don't need any special parts to get 4mm of shims under the ball nut. Simply get 2 3mm screws that are long enough to reach through the servo saver, the shims, and give enough threads to screw into the kit supplied ball nuts. Problem solved...
You can vary the amount of shims under the ball nut to adjust bump steer.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 03-11-2014, 01:47 PM   #1627
British Menace's Avatar
Just a quicky .... don't want to derail this new thread.
The Fireball Classic, held at Lincoln/ Nebraska, is going to include F1 this year. As long as enough turn up of course.
Look up Fireball classic on the Nitro on-road thread.
Thanks all.
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 03-19-2014, 03:36 AM   #1628
Force 10 Racing's Avatar
Is anyone running Futaba's 4PLS radio with their V2 Pro? Need some advice on how to adjust Off Throttle Braking (Drag Brake?), Throttle Curve (i.e.. traction control) etc. I've figured out the basics but the manual is a bible and most guys at the club I'm racing at are running Airtronics & other non-Futaba brands. The rear end wants to step out going straight at full throttle. I'm thinking this radio has the capability to have a progressive or delayed throttle response as opposed to Wide Open Throttle at 100%.
Thanks for any tips in advance.
A lot of people go through life doing things badly. Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting.
Steve McQueen Le Mans 1971
Force 10 Racing is offline   Reply With Quote
Old 03-19-2014, 03:46 AM   #1629
Pro10noob's Avatar
It is called expo on the Futaba transmitters.
That is on the steering and throttle channel.
Also the ESC can be fine tuned.
Most ESC's have a throttle profile from smooth to agressive.
Check your manuals.
Regards Roy
l===/o\===l
Old 03-19-2014, 03:55 AM   #1630
Thanks for the reply. Will look in to a manual for my ESC. Bought the car slightly used with a new Hobbywing "Just Stock" ESC but no manual for it. Will have to search online.
Old 03-19-2014, 08:19 AM   #1631
golgi's Avatar
Trader Rating: 14 (100%+)
Thanks all.
Regards
BM
I will definitely be there with my F1! I know several others are also planning to be there. On top of the usual group, about 5 more people recently got F1 cars in this area. So hopefully we have a nice big group to race in the Fireball Classic and the rest of the HOA series!
golgi is offline   Reply With Quote
Old 03-19-2014, 01:36 PM   #1632
idbdoug's Avatar
Trader Rating: 33 (100%+)
I have the exact speedo. Before I touch the radio, I would turn down the punch rate(start mode).The default is 7, turn it down to 2 or 1 especially if you are running rubber tires. If you have good traction, turn punch rate 1 higher number at a time to find a setting you like.
Link to manual:
http://cdn.shopify.com/s/files/1/010...k_ESC.pdf?1727
idbdoug
www.fantomracing.com
www.falconsekido.com
www.reflexracing.net
www.gizmoracingusa.com
idbdoug is offline   Reply With Quote
Old 03-19-2014, 03:22 PM   #1633
Link to manual:
idbdoug
Thank you! I was wondering which would be ideal to adjust first, the radio or the ESC.
Old 03-20-2014, 12:00 PM   #1634
kyle3333's Avatar
Does anyone know of a good Formula One body painter?
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 03-20-2014, 01:14 PM   #1635
It's been nearly 20 years since I last races and was doing asphalt oval racing. I was fairly competitive but I was known as the concourse king. If you're wanting an authentic F1 scheme, I've got the time to do it as I'm out on workers comp & have lots of spare time.
There is a professional company that does decals and custom painting and their jobs are top notch. F1PaintLab is the name.
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
