Tamiya F104 Version 2
#1607
Also, I'm not too familiar with Exotek front end but are you running any droop spacers on the Exotek front end?
Also, try a little preload on side springs and see if that helps inside tire lift.
idbdoug
#1613
#1614
here is what i run. esc behind servo then battery captured under the top plate. mini receiver mounted on top. car handles well.
#1616
I found Tamiya's grease, at 8$ a bottle... doesn't say what wt they are
-Soft (Green)
-Medium (Blue)
-Hard (Purple)
http://www.rcmart.com/tamiya-53175-f...m-p-18607.html
And i found CRC's tubes at TQracing
http://www.tqrcracing.com/shop/produ....asp?p_id=2862
-Soft (Green)
-Medium (Blue)
-Hard (Purple)
#1617
oil wont do it.
here, ive bought a number of things from these guys. look in the f1 section. some various wt greases in here. the diff gear grease should work for what you need.
link: http://www.reflexracing.net/110th-F1-Hop-Ups_c_65.html
#1619
#1620
I ordered the CRC tubes in 5000wt, 10000wt and 20000wt
