Old 01-28-2014, 06:41 PM   #1591
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by banquer View Post
Dear Cadman.
Can you explain wich tweaks must have to do to avoid traction rolls?
King regards.
Gluing sidewalls and getting ride height under 4mm has also helped our locals out ( on high grip carpet)Its also very important to make sure the rear pivot is free. There is a decent video somewhere on YouTube showing how to adjust the pod plate.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 01-29-2014, 07:10 AM   #1592
idbdoug's Avatar
Trader Rating: 33 (100%+)
Does anybody run the 21.5 trinity Killshot? If so, what is your stator and rotor recommendations ?
idbdoug
www.fantomracing.com
www.serpentamerica.com
www.reflexracing.net
www.gizmoracingusa.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 01-29-2014, 11:04 AM   #1593
Vyger's Avatar
Originally Posted by Marklas View Post
No such luck, at least in Nuremberg. I think if they were to release a new version or entire car it would be at the Tokyo (April) or Shizuoka (May) hobby shows.
http://blog.tamiyausa.com/
http://tamiyablog.com/
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 01-29-2014, 01:53 PM   #1594
mtveten's Avatar
Trader Rating: 27 (100%+)
idbdoug
I have had good luck with the Rpm maxzilla, turquoise rotor at 55deg @ 3 to 3.1 ratio. For comparison I run my to at a 2.9 to 3.0 and my reedy at 2.8 to 2.85.
mtveten is offline   Reply With Quote
Old 01-29-2014, 02:53 PM   #1595
idbdoug's Avatar
Turquoise rotor is 12.5HT correct?
I was leaning towards this combo
idbdoug
Old 02-04-2014, 01:16 PM   #1596
Hello all. Put my F1 on the track this weekend and found I had a hell of a time keeping the rear planted. Running 571/572 pits outdoors and added 28g of weight to the rear. Didn't feel like it was much help. Towards the later part of the main, it felt like the tires were finally gripping. Do the pits take about a race day (2 heats/1 main) or so to get "broken" in? Waiting on a local guys successful setup sheet to compare but from initial looks may be only fluids to change. Thanks.
Enjoying this rc hobby while I can!
teknorookie is offline   Reply With Quote
Old 02-04-2014, 03:10 PM   #1597
Are you running shorty pack or normal?
capt waffles
sobiski racer is offline   Reply With Quote
Old 02-04-2014, 09:14 PM   #1598
Shorty pack, moved forward.
Old 02-05-2014, 03:41 AM   #1599
Race indoors here on fairly low grip carpet. It took around 10/12 races before the Pits started to work for me, then they have been consistent. They aren't like touring car tyres where they give the most grip when new then get slower the more you use them.
terry.sc is offline   Reply With Quote
Old 02-09-2014, 11:28 AM   #1600
Today we had our second race of the tamiyacup season.
My ver.II was a bit faster then my TRF101 and the car performed extremely well, i was using a silvercan motor and i won Every finale from a guy who was using a hobbywing sensord brushless motor (the one they use at the ETS races) and had a lot more more power then me but i was able to beat him with a more smoother driving style.
addicted2blue is offline   Reply With Quote
Old 02-09-2014, 06:08 PM   #1601
clint's Avatar
Trader Rating: 23 (100%+)
Send a message via MSN to clint
Hey guys curious if the V2 has the corner hopping issue that the V1 pro car has?
If so is there any way to stop this from happening? thanks..
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 02-23-2014, 06:38 PM   #1602
idbdoug's Avatar
Does anyone have an extra f104v2 body mount plate part# 3405064?
Or do u know where I can purchase one because everyone is out.
idbdoug
Old 02-25-2014, 07:04 PM   #1603
Cadman1981's Avatar
idbdoug
You can try to ask TQracing to see if they can order it for you.
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 02-25-2014, 07:14 PM   #1604
Cadman1981's Avatar
Hey Guys, i raced my F1 this weekend, the car ran really well, i was able to reduce the traction rolling issues by putting the copper soft springs in the rear, and Tamiya Silver soft springs in the front. For the shock, i have a TRF shock, with an Orange tamiya spring, and 35wt oil.
I ran the 573 F1-medium fronts and 575 R1-soft rears from Pit Shimizu, it ran good. I also tested the 577 front F3-mediums and the 579 rear R3-softs, the car seemed to push a little more. It's a medium-high grip carpet.
What i noticed, in both cases, the rear axel would want to lift, and it would slow me down, i could hear the diff slipping. I tightend the diff a little more between each run to see if it made any difference, and i never saw one.
I played with the toe, camber and caster (i have exotek type front top arms)
Anyone have any other suggestions to try? I know i can go faster if the car would be planted in the tight turns.
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 02-27-2014, 05:03 AM   #1605
idbdoug's Avatar
Did u try a thicker side tube lube?
idbdoug
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
