Old 12-05-2013, 09:33 AM   #1546
Cadman1981's Avatar
Originally Posted by Cadman1981 View Post
But i actually had a question, in the page, it has "Includes Associated side pod springs. These are used to tune for steering response and pod level (tweak)."
Have i been using these springs all wrong??? i knew about the pod tweak, but I still have the issue of the rear inner wheel lifting in tight turns after the apex, i thought putting stiff springs here would help, but it made no change, so these affect the FRONT??
Anyone?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 12-06-2013, 01:44 AM   #1547
MarkBurgess's Avatar
As you know the spring itself doesn't adjust pod tweak, but the set screw that winds them in and out does.
I have run both Tamiya and Associated side springs on my F104 V2. Little difference between them to be honest. In my experience the side springs fine-tune how the rear works in the corner - the oil in the side shock makes a much bigger difference. I now run the Tamiya friction damper which gives a much more consistent feel.
For the lifting rear wheel I'd be looking at front end changes: tyres, front springs, making sure front pin moves freely, center shock oil and spring. Worth making sure the rear ride height isn't too big as well.
Hope that helps. You will also find a lot of good information in online F1 set up sheets - UF1 and rcformula1 are great resources for these
MarkBurgess is offline   Reply With Quote
Old 12-06-2013, 04:09 AM   #1548
idbdoug's Avatar
Trader Rating: 33 (100%+)
Anyone?
Try disconnecting 1 side of roll damper. Take a few laps and see if this improves or worsens the tire lifting. If it improves, go lighter on roll damper fluid and if it worsens go heavier on fluid. Also, what roll damper are you using?
idbdoug
www.fantomracing.com
www.serpentamerica.com
www.reflexracing.net
www.gizmoracingusa.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 12-09-2013, 10:09 PM   #1549
Cadman1981's Avatar
I'm using the kit stock damper and oil from the Dark edition f104V2
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 12-10-2013, 08:17 AM   #1550
robk's Avatar
Trader Rating: 22 (100%+)
Anyone?
If the wheel is lifting you have couple things to try:
Lots of front droop
Heavy side damper grease 100k or more on a tube damper
Move the battery as far forward as possible
Glue on sidewalls of fronts
Start widening car front first
Raise ballstud on inside of top arm at camber plate
Reduce caster if using exotek front end
Old 12-10-2013, 09:40 AM   #1551
JayL's Avatar
Are the new diff rings the v.2 uses really any better than the original f104 pro ones?
I wonder as a diff kit old ring style is only $28.99
and the new v.2 parts add up to $54.13
I am building a F1R2 car from scratch
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 12-10-2013, 10:55 AM   #1552
Vyger's Avatar
I don't know if there better than the old style rings or not. They look better coming out of the package than the older f103/104 rings. Most of time mine looked pitted and/or discolored. The newer rings look way better.
I do know the new rings are the same as the 417 sedan. I'm assuming Tamiya went with a universal set to reduce production and inventory cost.
Tamiya Road Wizard, F101ís, F102ís, F103ís, F103RSís, F103LM, F103RXís, F103RMís, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 12-10-2013, 11:02 AM   #1553
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
I don't have any pitted rings of the old type. The new ones are the same material. There is no performance difference between the two. Most likely Tamiya are just phasing out the old type.
Dan is offline   Reply With Quote
Old 12-10-2013, 01:31 PM   #1554
Vyger's Avatar
Maybe mine were just too old since some of the kits I'm referring to date back to 1993
Old 12-11-2013, 10:52 AM   #1555
Cadman1981's Avatar
Lots of front droop
I made my own front arms to have the caster adjustable, i will reduce the caster.
- Basically, the rear wheels are lifting because i have too much front grip?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 12-11-2013, 12:34 PM   #1556
Rick Vessell's Avatar
Yes. Something else to try is a stiffer center spring.
Rick Vessell is offline   Reply With Quote
Old 12-14-2013, 07:18 AM   #1557
ZZracing's Avatar
Send a message via Skype™ to ZZracing
ZZracing Titanium screws /Hobby Wing /Savox /Nvaracing / Star racing/Novarossi/Sanwa/Castle/Xcore/Yeah Racing/Tianhao UFO/Q-World/Venom/Orion/Sky Rc
Email:zzracing@126.com zzracing@foxmail.com
www.rzhobby.com www.zzracing.net
ZZracing is offline   Reply With Quote
Old 12-15-2013, 01:25 PM   #1558
Hello all...got a v2 coming in the mail. I feel a little lost jumping into f1 since I run sedans and sct's. So what spare parts are good to have? I apologize if this has been answered earlier in this thread. Thanks in advance!
Enjoying this rc hobby while I can!
teknorookie is offline   Reply With Quote
Old 12-15-2013, 01:34 PM   #1559
It's best to have some suspension arms, front&roll springs and the side links (it's better to change them with the carbon reinforced ones)
addicted2blue is offline   Reply With Quote
Old 12-16-2013, 05:39 AM   #1560
Cadman1981's Avatar
Has anyone drilled their stock chassis to move the links out? Like on the exotek flex chassis?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
