Like Tree1Likes
Old 10-28-2013, 02:36 PM   #1501
Typeone's Avatar
Trader Rating: 30 (100%+)
What about final drive what do u guys think about it I'll be running on a 100x70 asphalt track. Like I said I'm running 96/35 but I ordered a 33 so I'll be at 2.9 with 96/33. Also I'll be running a Reedy Sonic Mach 2 21.5.
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 10-28-2013, 02:37 PM   #1502
One last thing on the plates. Clean them with motorspray first to remove any oil or corrosion inhibitor.
Sydewynder is offline   Reply With Quote
Old 10-28-2013, 02:48 PM   #1503
Typeone's Avatar
Ok ill do that thanks.
Old 10-29-2013, 09:38 AM   #1504
Typeone's Avatar
What size diff balls go into a kimbrough spur gear? Also does a smaller spur gear help in a F1 car or it doesn't matter but as long as the FDR are the same?
Old 10-29-2013, 02:47 PM   #1505
When using a smaller spur the motor moves towards the rear axle and this can provide more rear grip.
addicted2blue is offline   Reply With Quote
Old 10-30-2013, 12:40 PM   #1506
Typeone's Avatar
ok i ordered a 88t but whats a good FDR thats going to keep motor temps low with a 21.5 reedy mach 2???
Old 10-30-2013, 12:57 PM   #1507
I've only been using a speedpassion V3 21.5T motor with a 93T spur/32T pinion combo on a large (30mx12m) indoor carpet track and the motor temps never get above 55C after a long 10 or 15 minutes driving.
Old 10-31-2013, 10:57 AM   #1508
idbdoug's Avatar
Trader Rating: 33 (100%+)
Hello
I have a Tamiya F104v2 with your +3mm rims for shimizu tires. Does this combo meets ROAR's max width for F1 class?
Doug Bryson
idbdoug is offline   Reply With Quote
Old 10-31-2013, 12:51 PM   #1509
Originally Posted by idbdoug View Post
Hello
Doug Bryson
If roar's max width is 190mm and your car rolls through the tech box it's legal. I know the r sector kit made some cars illegal because the tire sidewalls would drag on the sides of the tech box. Or running too much camber caused some cars to fail tech inspection.
Pretty sure I remember reading the exotek wheels where designed with this in mind and make the the f104 186mm wide so you can add shims and/or camber and still roll through a 190mm tech box.
racer robert is offline   Reply With Quote
Old 10-31-2013, 04:13 PM   #1510
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
Originally Posted by samsking View Post
Hey guys I have an issue with the rear inside tire lifting on corners. I have played with changing the tube lube from 10-20-30-50k with soft medium and hard side spring combinations and it did nothing to fix the problem. I am running on high grip carpet on pardus tires. Any ideas?
I experience this alot with pardus tires on carpet. Only solution I found was to use extremely thick lube in the diff. Downside is that the car gets loose under acceleration after a short time during a run. I have tried the full range of springs and tube lube, as well as changing rear track width.
Is anyone else have a better solution to this?
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 11-01-2013, 08:42 AM   #1511
Cadman1981's Avatar
I have been having this issue as well, but with RIDE R1 tyres. so far, i was suggested to get the Exotek flex chassis as a possible solution, or widen the rear pod links. But i can't confirm if either of those work.
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 11-07-2013, 10:52 AM   #1512
Typeone's Avatar
I have the Rsector kit to make the f1 190mm but how good is the hop up uprights in the picture and what are the advantages. Also how many spacers would I need to get the front to 190mm cause the rear is at 190mm with Rsector kit.
Old 11-07-2013, 12:07 PM   #1513
idbdoug's Avatar
If you have rsector front aluminum uprights run those, I actually like rsector's front uprights better than Tamiya's. They seem to have less play than Tamiya's, I have both Tamiya and Rsector front uprights
idbdoug
Old 11-07-2013, 01:21 PM   #1514
Typeone's Avatar
yeah but tamiyas are adjustable the rsectors are not. Performance wise are the tamiyas worth it as an adjustment?
Old 11-07-2013, 02:21 PM   #1515
idbdoug's Avatar
I thought your were asking which one of these 2 was better. Only adjustment missing from rsector is trailing position on upright shaft and at our track not many people run trailing. To me, it makes car harder to drive. As far strickly improving performance over stock, not to sure but maybe some of the UF1 racers in california might chime in with more information. But I would definitely get Tamiya carbon reinforced uprights over stock, durability.
idbdoug
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
