Car layouts and pics
#166
the reason why I put it on the esc wire is that I had better result on it, some people will say they like it better on the negative wire to the motor and some other will like it better on the esc wire.
#167
My T1R
#168
You can see them in my post a few post ago. Those ones you are using are great too.
Just thought I could help with the actuall name of them.
Stephen <><
#169
Originally posted by micros_rock
My T1R
My T1R
#171
C-SRACING powered yokomo sd
#172
what kind of connecters are those on your motor?
#173
The connectors are "corally" style plugs, some people use them for a quick change over.
#174
look like t27s to me, carpet tires
#176
its a control tyre for many carpet tracks
#177
Originally posted by Mr. Shookie
Try using the servo shims on the center of this parts tree.
http://www.speedtechrc.com/store/ebp...id=233&id=2145
It can bring your servo linkage right to where it should be. I hope this helps.
Stephen <><
Stephen <><
- Stan
#178
Originally posted by skinart76
Hey Stephen, I don't think I can bring the servo in any further. The mounting screw is already touching the lower pivot holder. Is there another way to mount the servo?
- Stan
- Stan
Left to right and front to back?
If you are a little bit heavy on the servo side try maybe shimming the rear servo mount just a bit in to help. It is realy a goofy design if you ask me..I still don;t quite get it. Maybe thats why I got a Yok...LOL
See what works, cause X ray does its fair share of winning so there design must have something good workign for it.
Take Care & GOD Bless
Stephen <><
#179
Finally got my car assembled and tested. Works good. Thanks for all the tips and pics. here's mine
