End Bell Timing vs FDR Changes
When running blinky I am wondering if I should run maximum timing on the end bell and find my gearing to reach 160F or lower the FDR and decrease the end bell timing.
Same question with boost. I am running max boost and I am a little under temp. Do I lower my FDR or move the end bell 1 notch up?
I've always been of the school of gear to the track then add timing for extra performance once geared correctly.
Same for boost. I generally don't use end bell timing with esc boost. Just creates heat
The esc boost is better for your motor because it normally comes in after an rpm range.
I always gear first then add timing. The reasons are simple, if you are undergeared for the track you will hit the rpm limit early and be slow on the straights, if you are overgeared you will have slow drive out of corners. Timing alone is not enough to over come these deficiencies. Once you have the gearing balance right, for drive out of corners and along speed along the straights, then start adding timing for extra performance. As the timing is rammed up, you may need to re-gear again.
When gearing is the first option then what would be the initial setting of the boost timing on the esc? Should.it be left alone first then altered after finding the right gear?
Whatever way you do it, be consistent in how you approach it. If i am driving a new track for the first time, i start with a very neutral setup and work up from there, for every setting that i have, be that esc, motor or chassis adjustment, start neutral and work from there.
I usually ask around and see what other people's experiences are on what the particular motor likes for timing, where it's most efficient. I then use that as a starting point and gear from there. Highly dependent on the track though. For the same track, but a different layout, I usually find a timing that works and just change the gearing from layout to layout.
Thanks for the feedback Roger. It has been awhile now until this matter became clearer to me. Thanks.
