Hobbywing Xerun V3
#692
Any help would be great here. I recently purchased a stock spec v3.1 esc and need to put in blinky mode.. The only way to do that is through the program box right?? I have a program box but every time I plug it in it says "please update software" which would be easy but I have a Mac.. Please help!! ���� and which software is that referring to the box or esc???
#693
Issue with v3.1 1s
I have several HW v3.1 1s 120A esc and have same problem with 2 of them. After a fairly hard crash, when you are sat on the line for 30 seconds or so and then nail the throttle (ie at start of final), there is a delay of a second or so before the car moves, then it goes as per normal. This happens every race now. Anybody seen this behaviour, and is there a fix or is the esc damaged? This wasn't happening previously
#694
Once the box has been updated, you can then select the mode for your ESC. It might request updating the ESC. If so, you can decide if it's worth it.
#695
#698
Jon.
#699
I picked up a 120a 3.1v esc. I bought. I hooked it up and my motor is running on its own and stuttering off and on? Any ideas? Is it junk? Thanks guys.
#700
V3.1 with a 4.5T 550
I have read the specs for the V3.1 and see that a 4.5T is too low according to the "specs". I have seen some knockoffs able to handle a 4.5T 550 without issue in a 4wd SCT. I would assume that it being a 120A esc, the V3.1 should work for me. Would the V3.1 handle this motor? I run indoor off-road carpet 4wd SCT.
#702
#703
I have the V3.1 with a 4.5 540 motor and in TC, it already gets pretty warm.
#704
Seems that the V3.1 AND SCT Pro have the SAME OUTPUT specs....changing the fan to one with a highr CFM rating could help with the heat.
#705
Well, I went with the V2.1 120a instead. I got it all installed in my SCTE 2.0 with my Ballistic 4.5T 550. I did some test hits on the street and that yielded no issues. I went dead stop to WOT to full brake with no hiccup. Actual track testing will be later this week. I will report my findings as soon as I can.
