Old 12-23-2012, 04:33 PM   #166
Please provide some handy modifiable blank pdf setup sheet, something like xray did
b.wihardja is offline   Reply With Quote
Old 12-24-2012, 12:05 PM   #167
Barry_Hughes's Avatar
Use the print function with the usb link!!!!!!!!!!
You can change the details of the car etc, then it will save a document with all the settings direct from the V3, in an easy readable sheet.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 12-27-2012, 02:47 PM   #168
PutAwayWet's Avatar
So, with the Orion 1s ESC out, can the actual Hobbywing V3 1s model be far behind? Any word?
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 01-03-2013, 04:58 AM   #169
Hello,
Anyone know if the temperature security work with a gm pro ?
It s work with the gm esc, maybe same with the hw v3 ?
Manson is offline   Reply With Quote
Old 01-03-2013, 06:36 AM   #170
banquer's Avatar
I run normally with a gm delta pro 7t (equivalent aprox. A 3.5t) and works very well.
King regards.
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 01-04-2013, 05:35 AM   #171
King regards.
Temperature monitoring don t work with my gm pro
Old 01-04-2013, 11:33 AM   #172
Send a message via ICQ to MattW
The older GM "pro" motors - with the more enclosed cans and sensor port coming out just under the bearing do not have temperature sensors.
The newer GM "pro" motors - with the more vented cans and sensor port vertical behind the solder tabs to have temperature sensors.
MattW is offline   Reply With Quote
Old 01-04-2013, 02:05 PM   #173
tested on this
http://www.graupner.de/fr/products/5...0/product.aspx
Old 01-05-2013, 02:28 AM   #174
That is newer motor, they do have temp sensors in them.
Old 01-05-2013, 08:58 AM   #175
I run the gm race 2012 motors (latest ones) with the hw v3 mine pics up motor temp fine, unless I turn thermal protection off then it does not give temp reading.
It measures very good too I had it coming off at 136 oc (not f) and the motor is an animal I can't kill it! It is a very quick combination too.
J
Jampot is offline   Reply With Quote
Old 01-05-2013, 09:06 AM   #176
Thanks jampot,
I have to activate the thermal protection to see it with the 2in1 card
Old 01-05-2013, 09:34 AM   #177
Originally Posted by Manson View Post
Thanks jampot,
I have to say yes as my one does not give a temp if its off so set 125 degrees's obviously I turned mine off in an attempt to find the limits of the motor then checking after the run with a temp gun! Yeah I could not blow it in 5 mins! The motors are insane!the speedo feels real good too I have it just set and leave it never play no need.
Old 01-06-2013, 06:28 AM   #178
Being new to hobbywing i have a ?. If i choose not to take a laptop to the track, will i need 2 seperate program boxes if i want to run 2 seperate profiles? ie: i run 17.5 blinky, but would also like to get some practice time running boosted as well. i just didnt see when booting up the program box any way to just load a profile unless you change each setting. hope ya'll understand what i am trying to do..
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 01-06-2013, 06:38 AM   #179
narcotiks's Avatar
Easiest thing to do would be to load the boost profile and run it with or without boost settings depending on what you feel like running.
narcotiks is offline   Reply With Quote
Old 01-06-2013, 07:33 AM   #180
lewis110's Avatar
Load the boost firmware, then once you take the timing and turbo to 0. The esc will automatically start blinking. Gotta love the V3!
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Sponsored Links
Hobbywing Xerun 120 V2 ESC for 1/10 cjtamu Electric Off-Road 289 09-15-2014 04:52 PM
HobbyWing XERUN 13.5T( V3 ) YZFAndy Electric On-Road 6 03-04-2011 05:48 PM
SEO by vBSEO 3.5.0
