Wheel/Tire issue (brushless)
I have at T2 06 and it has a mamba max 7700 motor with 3 cell lipo. i tried using rubber tires and they ripped off the wheels. i went ahead and put on some foams and after the first time i tried going full throttle, three of the foams flew off the tires (never saw that before). i could not get more than 50mph because of traction issue.
I would rather use foams. Any suggestions on something that will be able to handle the power?
thanks.
thanks.
thanks.
thanks.
this was bashing in a parking lot. i really want all out speed which is why i went with the extreme 3 cell. Trying to do 70+ with it.
How quickly are you punching into the throttle? IF you're going full on, the torque may pop them loose...... although at 50 I still think it shouldn't, as many mod cars run that fast. Try rolling into the throttle if you are going on all at once, that way there isn't a full burst to try to rip them all at one time.
What Tires are you using??? Are your foams trued??? Most folks run the foams past 100mph for speed runs...
I start it off slowly and than punched it midway through. As soon as I punched it, the three foams flew off. I'm going to try regluing them with CA glue and see if they hold.
I think it was just a generic foam tire. Can anyone recommend a good foam tire? I was thinking maybe the ATS tires that come with the schumacher fusion.
