BRUSHLESS COMBO ADVICE
Hi all....
im after a good combo iv got a bit of money its going in a 1/10 car.....
I dont mind spending on ad on's if you see what i meen..batts and stuff....
I just want a mega fast car..
Its a hpi 4wd on road car....
What you all reckon..
Thanks Agen people..
what are you going to use it for? speed runs/bashing? racing?
Hi m8 speed runs...
Just want a car what is quick of the mark and good at top speed...
http://www.amainhobbies.com/product_...-Brushless-ESC
that would be insainly quick, also you can play with boost and turbo only for 2s lipo, which in a tc car is most likely. or you can go much cheaper and buy a combo kinda like:
http://www.amainhobbies.com/product_...le-1406-5700kV
inless you want to change your gearing to mod1 those are 2 good options for you. but if you do want to mod your tc a better speed run option would be something like this.
http://www.amainhobbies.com/product_...r-Combo-5150kV
sorry their all very brief and from the same site. just had to be kinda quick with this post
Thanks m8 i thought i need to go lower like 9t motors or under but im wrong agen in I
The top 2 the esc and the moter what are on there own the esc can take a 3s lipo it sez...:-)
rule of thumb is lower the cell count, low wind motor, higher wind motor more cell count. lower kv motor higher cell count higher kv motor lower cell count. if you plan on running like a 3s, 4s, 5s, ect.. you will need a lower kv, or higher turn motor to bring down the rpms, but then you can throw more gear into it.
Thanks m8
