Old 02-03-2005, 10:27 AM   #1
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Default Charging batteries
I need to charge 5 2100mah NIMH AAs in a series. I also would like to charge the same in a series of 8. My reciever and transmitter batteries. How do I go about this?
I have a Novak DigiPeak with the digital voltage/amperage screen. No Negative Delta Peak settings though (which is what Team Trinity says you should use to charge NIMH). Pulse rate is adjustable from 0-10 amps, linear from 0-5 amps, trickle from 0-300 milliamps.
Other than that, all I have is a regular tx/rx charger that only puts out 45mah, 46 hours to charge. I'm willing to purchase a new charger, as long as it's cheap, around 30 dollars, but I don't know what ones will work. I don't race, so I'm not going to spend 125 dollars on a Novak or whatever to charge some AAs.
Also, if it takes 46 hours at 45mah to charge one 2100mah AA, does that mean it takes 233 hours to charge 5 in a series?
HVAC25000 is offline   Reply With Quote
Charging Batteries?????? Drift_Buggy Electric On-Road 2 01-06-2007 01:48 AM
charging batteries MrUnlimited Electric On-Road 3 12-01-2005 08:44 PM
Charging Batteries Blakesrc Electric On-Road 1 11-16-2002 09:42 AM
Charging UMH Batteries Zuffy Electric On-Road 1 08-24-2002 10:08 PM
Charging Batteries Dragon Electric On-Road 20 01-30-2002 04:30 PM
SEO by vBSEO 3.5.0
