Old 02-01-2005, 12:51 AM   #1
Default TRF Shock rebuild
I have just rebuilt my TRF shocks for my mi2
I filled the shocks with oil (35w schuey oil) to the top of the housing so there was no air in the shock, but although the shock feels very smooth I get full rebound from the shaft (shaft extends to it's full extension).
Is that wrong and if so Why?
What will it cause/
Also my front two shocks had a red damper rubber between the top of the bladder and the housing, but the rear did not, should I have put it back and why.
The shocks came on the car when i purchased it second hand, so it's the first time I have had them apart, so i'm not sure what normal should be.
ratter is offline   Reply With Quote
Old 02-01-2005, 05:46 AM   #2
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
all TRF dampers comes with that red foam on the blader.
i sugguest you to put it back
KREATOR1 is offline   Reply With Quote
Old 02-01-2005, 06:06 AM   #3
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
I believe that most people don't use the red foams on top of the bladders.
Airwide is offline   Reply With Quote
Old 02-01-2005, 08:30 AM   #4
Send a message via AIM to GroffBall
if you take the foam out it will allow the bladder to compress and you shouldn't get that harsh rebound. I don't use them in mine.
GroffBall is offline   Reply With Quote
Old 02-01-2005, 10:05 AM   #5
razzo's Avatar
Send a message via Yahoo to razzo
actually... if you look at setup sheets for TRF cars with TRF shocks, almost all of them use the red foam. You might feel like it's a 'hard' rebound, but once the shock's built with a spring on it, the spring still over powers it. It's there so you get a consistant rebound rate through out the rebound stroke. You can even change the rebound rate with same oil by replacing the red foam with black or clear o-rings. These are best shocks on the market for a reason.. no other shocks let you do that (well, I think you can now come close with Rayspeed optional parts with Yok shocks)
razzo is offline   Reply With Quote
Old 02-01-2005, 05:13 PM   #6
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
I gotta admit it was something that I was worried about a bit when I first built my shock but..... I've not had a problem with the car's handling. Its great so bring on the red urethane!!
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
how often do you rebuild your shock dampers? TRF-Powered Electric On-Road 16 05-24-2010 06:32 PM
WTB shock rebuild kit fenix R/C Items: Wanted to Buy 0 08-25-2006 02:30 AM
F/S; Losi Shock Rebuild Components NIP Mr T-Maxx R/C Items: For Sale/Trade 3 09-01-2005 07:53 AM
tc3 shock rebuild kh15 Electric On-Road 7 01-15-2005 12:18 AM
TC3 Shock Rebuild teamray Electric On-Road 4 12-09-2004 11:14 PM
SEO by vBSEO 3.5.0
