Like Tree1Likes
Old 06-26-2014, 10:26 AM   #1186
Jiggawatt's Avatar
Trader Rating: 18 (100%+)
What am I missing here? The space for the pinion seems small. The largest I can fit is a 25 with the stock spur which comes out to 7 fdr.
F A T A L . D E S I G N S
Jiggawatt is offline   Reply With Quote
Old 06-26-2014, 01:09 PM   #1187
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
What size is the stock spur again? If a am correct it's for mod basically which means you would only want to use a 19-22 size pinion. Most stock class guys are using a 88-96 64 pitch spur. Them you would be able to get a pinion range in the high 50's depending on your spur choices from that point.
Josh-n-ya is offline   Reply With Quote
Old 06-26-2014, 01:36 PM   #1188
Jiggawatt's Avatar
Stock spur is 85. I can only fit a 25 pinion in there. Nowhere NEAR a 50
Old 06-26-2014, 01:57 PM   #1189
The Kit spur is 48dp and my car came with an 82 spur.
Kimbrough spur gears fit
I was running 27/81 at the weekend which is 6:1.
If you are running 17.5 blinky then you will need a lot smaller spur gear (around 66 for 48dp).
Lantern Rouge is offline   Reply With Quote
Old 06-26-2014, 02:19 PM   #1190
Jiggawatt's Avatar
Thanks, Ill try the 66-70 range
Old 06-26-2014, 02:38 PM   #1191
Josh-n-ya's Avatar
You should switch to 64p gears. They are a lot smoother.
Old 06-26-2014, 08:36 PM   #1192
cyanyde's Avatar
Isn't the stock spur an 84T 48DP?
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 06-26-2014, 10:16 PM   #1193
Josh-n-ya's Avatar
84 or 85 I forgot 48p. Its for mod.
Old 06-27-2014, 10:39 AM   #1194
trigger's Avatar
Wink
64 pitch doesn't make the car smoother than 48pitch. It just allows for finer gear ratios adjustments.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 06-27-2014, 03:10 PM   #1195
Josh-n-ya's Avatar
Lol, that's what I meant. /\/\/\
Old 06-29-2014, 10:56 PM   #1196
Josh-n-ya's Avatar
Love my new Blitz bodies. Also decided to test out going back to 18mm stock steering arms with 3mm shims. I'm sold. They felt great and plenty of steering at high speeds.
Team Titan ARC R10 190mm EP Touring Car-img_0118.jpg   Team Titan ARC R10 190mm EP Touring Car-img_0119.jpg   Team Titan ARC R10 190mm EP Touring Car-img_0120.jpg
Old 07-06-2014, 09:38 AM   #1197
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by nikos2002 View Post
Just wanted say had a good time meeting skypilot today, watching him run a few heats with his R10. Maybe even helped a little as we talked some set up - but he looked pretty good with the car.
Now I have the itch to get back out my ARC and run more on-road!!!!
think I found the problem with the setup, the right rear axle drive pin, (the part the blade fits on) was broke, but only half of the pin so the blade would work, and then slip off and not and back and forth. explains why it would be good for a few laps then turn to crap, then get good again.
good meeting you too.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 07-22-2014, 01:18 PM   #1198
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
WOW, I go away for a little bit and look what happens.....
Just wait -- they will be talking about us soon.........
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 07-22-2014, 01:26 PM   #1199
patorz31's Avatar
So when is the new r10 2014 or 2015 coming? I am patiently waiting for it...
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is online now   Reply With Quote
Old 07-25-2014, 01:48 AM   #1200
Red RC just posted this,
http://www.redrc.net/2014/07/arc-r10...it/#more-84209
Kody is offline   Reply With Quote
Tags
arc r10, rc-world, team titan
