Old 05-15-2014, 04:48 PM   #1081
trigger's Avatar
With the use of the 22mm bell cranks, there is limited space between the rack and suspension block. Zero shims will fit. I run 20mm bell cranks and 1.5mm so just a bit more flexibility with adjustments with Ackerman. The 8.5 mm aids with smoother steering.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 05-15-2014, 06:25 PM   #1082
Professor's Avatar
trigger
i agree, i run the same as you 20mm but with 1 mm shim & love the way the steering responds & smoothness, i thought the std set up was good untill a friend told me to try this way
marc
when you do get around to trying it i think you will be pleasantly supprised at how good it is, but when you get there
great feedback also, just a shame we dont have carpet tracks here in aus to run on
VBC RACING-R1 WURKS AUS--HOBBYWING--SILVERBACK--MAD GRAPHICS--BLITZ
Professor is offline   Reply With Quote
Old 05-15-2014, 07:57 PM   #1083
NEED-MORE-SPEED's Avatar
The 8.5mm Steering plate is on Back-Order at the moment.
In the meantime: I'm going to try using 3.5mm shims on the Ackerman while still running the Standard 18mm Bell Crank, (never ran more than 2mm) so it will be interesting. This should give somewhat of the same feel as using the 20mm Bell Crank option bits and 1.5mm on the Ackerman shim. I know it won't be the same but will get me in the ballpark for a general feel.
I'll let you guys know what I think in a couple days. I'll have another 2 day weekend at the track (Sat. & Sun.)
Sponsored By: ARC USA Team Driver - Hobby Authority Distribution - Team Maclan Racing
Marc
Cincinnati, OH
NEED-MORE-SPEED is offline   Reply With Quote
Old 05-16-2014, 12:28 AM   #1084
It won't give you the same feel, because it's the length of the bell crank that determines the arc that the rack travels through.
That said, I borrowed some 20mm cranks last weekend, and didn't feel a great difference tbh. The steering maybe felt a bit more linear around centre if anything.
The kit ones are the same length as what Yok us on the BD7, which should maybe be a clue.
cyclonetog is offline   Reply With Quote
Old 05-16-2014, 08:01 AM   #1085
I figured that would be the case as the 20mm bell crank will give more leverage on the rack over the 18mm. My steering with the standard kit (18mm bell crank) feels damn good using 1.5mm Ackerman. But getting those option bits are on my list of things to test.
Marc
Cincinnati, OH
Old 05-16-2014, 10:01 AM   #1086
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Man I wish I could go test and race as much as you get too.
Josh-n-ya is offline   Reply With Quote
Old 05-16-2014, 12:47 PM   #1087
I would say I'm fortunate to have two nice indoor facilities to race/test at. One is 10 minutes and the other about an hour away, so getting in an abundance of laps isn't an issue. I'm also in the middle (30 minutes) both directions, two dedicated asphalt tracks. I'm a carpet runner but do plan on getting on the asphalt within the next few weeks to see what's good
Marc
Cincinnati, OH
Old 05-17-2014, 07:18 PM   #1088
skypilot's Avatar
Trader Rating: 14 (100%+)
the spring rates in the manual are listed in "g" how does that compare to lbs.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 05-19-2014, 10:28 AM   #1089
skypilot's Avatar
Anyone?
Old 05-19-2014, 12:12 PM   #1090
http://www.petitrc.com/reglages/1-10...pringChart.pdf
300gf/mm = 3.0
280gf/mm = 2.8 etc.
Old 05-19-2014, 01:08 PM   #1091
In round figures 26 = 15lb, 28 = 16lb and 30 = 17lb.
Lantern Rouge is offline   Reply With Quote
Old 05-19-2014, 01:11 PM   #1092
nikos2002's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to nikos2002
red spring: .36 kfg/mm = 20.1 lbs/in
white spring: .33 kfg/mm= 18.4 lbs/in
yellow spring: .30 kfg/mm=16.7 lbs/in
green spring: .28 kfg/mm= 15.6 lbs/in
blue spring: .26 kfg/mm=14.5 lbs/in
Hobby Authority Distributions Marketing Director
** www.hobbyauthority-dist.com
Sponsored By: Maclan Racing, XRay/RC America, J Concepts, Xpert R/C, G Force USA, X Factory, Boom Graphics, Hobby Authority
nikos2002 is offline   Reply With Quote
Old 05-19-2014, 02:07 PM   #1093
Anyone?
Here is the conversion.
Example:
Short Blue Spring .26g ".26 divide by .0179 = 14.52 pounds"
Marc
Cincinnati, OH
Old 05-19-2014, 06:04 PM   #1094
skypilot's Avatar
thanks
Old 05-19-2014, 06:17 PM   #1095
Josh-n-ya's Avatar
thanks
Was that enough spring rates for you. Lol
Tags
arc r10, rc-world, team titan
SEO by vBSEO 3.5.0
