Team Titan ARC R10 190mm EP Touring Car
#1066
I noticed that as well..... However they are still selling the original R10 so not sure A Mains rational reasoning for dropping the 13? Time will tell
#1068
There is a noticeable difference in handling from the "kit" arms to the "hard" (on carpet anyway), not sure about asphalt, but would think you'll get similar results. The car is more responsive on carpet, gives more initial steering, chassis is precise and has an "immediate" feel. Also the hard arms are practically bullet proof. My first weekend with the kit arms I broke one, 6 weeks using the hard arms I haven't broke an arm yet, unless I got lucky receiving a set of superman composites
The split blocks gives a little more chassis flex and a wider range of tuning (arm sweep, toe and track width). There are tiny notches on the side of the split blocks for reference so you know exactly what changes you made.
EXAMPLE:
Split blocks in the front "Notches Pointed Out" using the kit (FF) solid suspension bracket you'll have a 1* front arm sweep.... "Notches Pointed In" will be stock track width and zero arm sweep
Split blocks in the rear "Notches Pointed Out" using the kit (RF) solid suspension bracket you'll have 2.5* rear toe, but will take away 2mm of rear track width... "Notches Pointed In" will be stock track width and 3* rear toe.
I noticed a difference when using the split blocks. IMO I think on a lower bite surface these are a great tuning aid, achieving slightly more mechanical grip over the solid suspension blocks. But on higher grip surface I think the solid suspension blocks will probably be better.
Hope that helps
EXAMPLE:
Hope that helps
thanks for that, as i got 4 x ( unidentified )split blocks in a bag with a 2nd hand r10 i was unsure as to any difference
#1072
For the different combinations of the suspension brackets including the split blocks see -
http://www.arc-rc.com.tw/image/suspe...acke_Chart.pdf
#1073
As most of the companies, I know ARC has tested some stuff for the Worlds, but no definitive plans for an update just yet.
When I know, I will pass it on to you guys.
#1074
Don't know why they dropped it off the list, we haven't talked with them about that, will have to look into it.
#1075
#1077
NEW CARPET SET-UP
I've been working hard over the past 7 weeks with the 2013 R10. I've ran (not exaggerated), over 200 packs and every other pack ran, I tried something different. I've taken several "notes" from one set-up to the next and I'm finally pleased to share what I've come up with.
Last night I found a set-up that gave me that wow feeling (high-bite carpet). I've found other set-ups that gives the chassis fast laps in the beginning, but fads later in the run. Some others that are just ok in the beginning and gets slightly better later on. Set-ups that stay consistent throughout the run but wasn't the ticket.
The chassis is fast, consistent, easy to drive, no fading and I was turning the same fast lap times during the last minute of the run as I was in the beginning.
#1078
CARPET SET-UP
Here it is
#1080
The reason I haven't experimented with the different bell-cranks: Most of your manufactures that offers a kit racer, doesn't give you that option? The bell-crank in almost all kits today, is what it is and that's what you have to work with, from my past kit experiences... So I planned on saving the best for last!
I did find running 1.5mm Ackerman shims with the stock bell-crank, 3 mm shims for bump steer offers a super smooth steering, and tons of it
