Old 02-11-2014, 08:05 PM   #901
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Originally Posted by skypilot View Post
yes, but that's the only to get to the desired ratio.
if I could get to 25.5, 21.5 or 17.5 ratio with a 106 spur I would. but I can't, so I don't.
What exactly are you trying to achieve? What class are you running in and what motor are you using?
Josh-n-ya is offline   Reply With Quote
Old 02-11-2014, 08:36 PM   #902
TOP F1EX's Avatar
all different ratios for motors. can you be specific?
T.O.P Rebel F1 / T.O.P Photon Ex
TOP F1EX is offline   Reply With Quote
Old 02-12-2014, 08:36 AM   #903
skypilot's Avatar
Trader Rating: 14 (100%+)
I run stock...my car is geared with a 98/50 spur/pinion combination...I purchased the flex motor mount and the pinion hit the new inside upright that supports the front of the motor plate and also attaches to the top deck. I did not want to change to a smaller spur/pinion combo so I replaced the new upright with the stock one. I was advised that this could be a issue. So now I will put a smaller spur/pinion on so I can use the new support..
The you said whatever about 25.5 and 21.5 which had nothing to do with my issue. Then I said whatever I did in response.
My point about the 106 spur and reason for not wanting to use a smaller spur is because I am a firm believer that a larger spur is better for overall performance. Acceleration, braking, corner speed. For example. .and these are just made up numbers. ..
If you running a 3.6 gear ratio with a 98/50. Your car will perform better then running a 3.6 gear ratio with a 92 /43.
Once again pinion size was made up. Don't correct me.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 02-12-2014, 11:16 AM   #904
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
skypilot - can you take a picture of where the gear is hitting the upright and send it to me at nick.malato@viper-rc.com
This way I can show the ARC engineers and see why this is happening for you. Thank you.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 02-12-2014, 12:35 PM   #905
This still doesn't make sense to me, but you're definitely not the only person I trust who's mentioned it.
The only thing I've really noticed from different sizes for the same gear ratio is the handling difference from moving the motor's weight forwards / backwards a few millimeters.
-Mike
Old 02-12-2014, 01:03 PM   #906
skypilot's Avatar
Nick. Will do when I get off work.
Mike. think of the size of the pulleys on the spur shaft. Is it easier to spin with a 100t spur or 80t spur. Now think about braking.
Remember when the drive train upgrade for a xray was changing from a 1.8 internal ratio to 1.9 or 2.0. Same principle. ..
Old 02-12-2014, 01:32 PM   #907
sosidge's Avatar
I'm afraid your faith is misplaced. Running an oversized spur makes no difference to the car. Running the car without any middle brace on the top deck will.
Large pulleys were introduced to decrease belt wrap and improve efficiency. The idea that a different internal ratio is intrinsically faster is all marketing hype.
Old 02-12-2014, 03:59 PM   #908
skypilot's Avatar
Like I said. I AM A FIRM BELIEVER.
You don't have to agree. My results and the way MY car feels to me are what's important here.
Old 02-12-2014, 06:01 PM   #909
skypilot's Avatar
email sent
Old 02-12-2014, 06:06 PM   #910
trigger's Avatar
I personally prefer 88-92 tooth spur gear max with spec classes. If i ever get the balls to run mod, i would switch to maybe a 110 spur to start. 64 pitch btw
Changing spur gears isn't a big chore at all.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 02-13-2014, 01:48 PM   #911
Scott B's Avatar
Trader Rating: 43 (100%+)
Got my car yesterday (found a great deal on in the forsale section) and started going thru it and hope to have it ready for Speedworld on Saturday. Looking forward to running it since I haven't run much electric in a year or so.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 02-13-2014, 03:56 PM   #912
trigger's Avatar
^^^^^^You are gonna love the car. Especially if you're just starting again. Car doesn't fight back much. Easy to drive with standard asphalt setup. Did you get the 2013 version or original? Either way, both capable cars. Have fun.
Minh Nguyen
Old 02-13-2014, 05:00 PM   #913
Josh-n-ya's Avatar
Go to ARC facbook page and under I think photos are setup sheets. Look for Hara's setup and you can start with that. Good for mod and 10.5 which speedworld does.
Old 02-13-2014, 07:15 PM   #914
skypilot's Avatar
I gotta say I am very impressed with the support from ARC I have received on my issue with gearing and the upright.
Thanks again..
Scott B. we know each other don't we? This is Ritchie from Turtlemaster Racing
Old 02-13-2014, 07:19 PM   #915
Scott B's Avatar
Thanks again..
Yes sir... We first met at SIR for the nationals, I was up there with Javier arroyo... . And we've run into each other at a few other races I believe.
Tags
arc r10, rc-world, team titan
