Like Tree1Likes
Old 02-06-2014, 05:11 PM   #871
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Originally Posted by [email protected] View Post
Congrats to ARC for adding a great racer in Josh. I know he's a committed racer and will rep the brand in a great positive manner. Congrats to you too Josh, well deserved!
Thanks Bro!
Josh-n-ya is offline   Reply With Quote
Old 02-07-2014, 05:40 PM   #872
Does anybody know which shafts will fit the r10? so front and back. Front I would prefer double joints.
Mine are slightly bend and I've heard that (If I remember correctly) 3racing shafts would fit and are quite durable as well. Not sure if it was 3racing though and which part number.
Anyone using other swing shafts that would fit the ARC's outdrives?
Thanks in advance.
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 02-07-2014, 06:03 PM   #873
Josh-n-ya's Avatar
Thanks in advance.
Go to shopviiper.com! Front Double Jointed CVD (R109009)
Rear regular CVD 44mm (R109005) I haven't bent or broke any of mine ever! Great quality for sure! When I ran an xray I broke several and had to buy replacement grub screws and collars and fix them cuz they were so darn expensive to buy all new CVD's!
Old 02-09-2014, 11:31 PM   #874
Trader Rating: 17 (100%+)
Make Sure that if and when you do buy the ARC double Jointed shafts, you check the pin positions, make sure you fully dismantle the joints and grease them accordingly before running them. While reassembling the shafts assembly make sure that the pins are on the same axis. Out of the box or package the pins are not on the same axis which will causes binding.
SANWA / TEAM ORION / PRO-LINE / PRO-SPEC / P1 BRAND / PROTOFORM / ACTIVRC
I'm not a Business man, but I'm the Bizzness man!!!
Sean Williams is offline   Reply With Quote
Old 02-10-2014, 01:58 AM   #875
Below you all will find a setup that I recently used on medium grip carpet. I have attached the results along with setup and photos....enjoy! The car was unbelievable! This car really turned a lot of heads at the track.
Setup to follow..having trouble uploading file to big!
Old 02-10-2014, 07:04 AM   #876
Josh-n-ya's Avatar
I haven't needed to disassemble mine and they have been working fine for almost a year now. When using associated black grease. Just squeeze inside joints and use a small piece of shrink tube to cover joint. Keeps it lubricated for a few race days. Or you can run dry with no worries.
Old 02-10-2014, 10:03 AM   #877
Joven M's Avatar
Actually Sean is right. The ARC DCJs are built incorrectly from the factory. All of my shafts came with the pins crossed. All of them chattered until Sean told me about the problem. So I moved the pins so that they are on the same axis. Chatter eliminated! Thanks Sean! Good job this past weekend! First time with the new car. TQ and the win!
ORCA USA / 1UP Racing / ActivRC
Joven M is offline   Reply With Quote
Old 02-10-2014, 10:22 AM   #878
sosidge's Avatar
My DCJs are the same! Never thought to check it. Been running a car with very expensive yet wrongly built driveshafts for a year. Feel quite let down by ARC. The DCJs were smoother but obviously only because they were operating at a smaller angle.
Old 02-10-2014, 12:12 PM   #879
Sosidge.....
I don't believe they were purposely built incorrect by ARC, I believe all manufacturers package them together with the understanding that you must disassemble to grease and lube before use, so the orientation of the pins out of the package should not be taken for granted. People are doing themselves an injustice if they are not disassembling any NEW DCJ's and greasing them before using. As far as I am aware there isn't one DCJ manufacturer that lubes there product before distribution.
Yes...the pins need to be re-installed on the same axis after lubing. Give it a try and follow up on the thread with your findings ok.
Old 02-10-2014, 12:14 PM   #880
My Setup!
Old 02-10-2014, 12:42 PM   #881
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Congrats on the success with the car Sean appreciate the good words!!!
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 02-10-2014, 12:43 PM   #882
nikos2002's Avatar
Ever since we have been involved with the car, no one has even commented that they had an issue with the DCJ's - not even the chatter.
I will send the info to ARC so they are aware of it.
Nick Malato
Old 02-10-2014, 04:16 PM   #883
nikos2002's Avatar
ARC has already responded and asked me to post this
"And we will fix all coming DJ CVD to make the pin at same axis to fix this problem, we sell lot DJ CVD, no one has this complain, but since they have a good suggestion we will follow it."
Thanks everyone -- making the product better, all the time!!!
Nick Malato
Old 02-10-2014, 04:36 PM   #884
Thanks guys for answering the DJ CVD question and a good thing ARC is willing to listen to feedback.
Now one more thing; how do I change ackermann on the ARC? Because adding or removing shims on the steering plate doesn't seem to change ackermann.
Now, I noticed there are various steering plates available and also bell cranks in various sizes.
Could anybody explain me what these plates and cranks exactly do and what combination/setup will give you more and less ackermann?
Would like to reduce my ackermann settings.
Modified 4 life
Old 02-10-2014, 04:47 PM   #885
skypilot's Avatar
Trader Rating: 14 (100%+)
just installed the floating motor mount, now my pinion does fit, the motor doesn't move far enough forward, and even it did, the pinion still hits the inside motor mount support.
I know a lot of people are using them so I'm assuming I did something wrong..
pics of your install please
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Tags
arc r10, rc-world, team titan
