Old 09-21-2013, 07:02 AM   #631
Originally Posted by Bigger Brother View Post
Doesn't actually confirm David will drive the ARC car though
I guess we'll have to wait and see if he'll be racing for Zen and ARC, or maybe just providing support and his marketing expertise.
He's a great ambassador and amazing driver, so will be interesting to see how this all works
I have received confirmation from jones that he will be an arc driver. With tc not really being his thing. I hope he gives it a good crack.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-21-2013, 09:24 AM   #632
pcar951's Avatar
Trader Rating: 19 (100%+)
Has anyone tested with the flex motor mount setup? How does it impact handling, corner speed ect.
Jim C.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 09-21-2013, 11:19 AM   #633
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Cyrul - Spashett --- together again!!! It just goes to show that the ARC folks are moving in the right direction in finding quality folks to give feedback and support
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 09-21-2013, 03:28 PM   #634
reg
Hi,
Iv just picked up a pre 2013,
Could someone point me in the direction of a setup for low grip carpet using all the std kit stuff please,
Ill be racing at the same venue as Mr Spashett tomorrow so ill get some pointers hopefully
reg is offline   Reply With Quote
Old 09-21-2013, 05:54 PM   #635
Jim C.
it changes the feel of the car. Gives it more on power steering. Perhaps at the expense of stability.
Old 09-21-2013, 05:56 PM   #636
Originally Posted by reg View Post
Hi,
We dont race on carpet in aus. But I would look at josh cyruls setup from late 2012. I actually tried it outdoors and it was very smooth to drive. It would have used mostly kit parts. Look for the one with the lower shock position inboard
Old 09-21-2013, 08:51 PM   #637
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Just saw that shopviper.com now has smaller 64p spur gears in stock. Yay! They seem to work better for some reason. I rebuilt my shocks with associated 30 and with the green springs feel like it should be good. I am still learning even shock oil (cst)! Haha! Where can you find just set ups for ARC? Is there a specific place on ARC facebook page?
Josh-n-ya is offline   Reply With Quote
Old 09-22-2013, 11:25 AM   #638
nikos2002's Avatar
On the ARC USA Facebook page look at the pictures - the set ups are in there.
You asked for the parts - we listened. New rear hubs in stock as well!!
Nick Malato
Old 09-22-2013, 02:32 PM   #639
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Just wondering what the difference is with the new rear hubs (part number 109023) to the 2013 kit ones?
Thanks.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 09-22-2013, 05:57 PM   #640
Thanks.
It is the same part, the new part number contains 2 pieces, instead of the original part having one side per unit.
Old 09-22-2013, 07:08 PM   #641
Josh-n-ya's Avatar
Thanks again! Can you stock Blitz bodys as well!
Old 09-22-2013, 10:46 PM   #642
nikos2002's Avatar
What an interesting idea...............
Nick Malato
Old 09-22-2013, 11:00 PM   #643
Default Split block
Hi
Know it'a a setup choice , but if you run split blocks rear , do you run cut inside or cut outside mostly?? . All summer I have run cut outside on asphalt
Thanks in advance
Xray T4 2014 / Orca VXX / Orca 5t
Team Xray-shop.dk
johnsen-dk is offline   Reply With Quote
Old 09-26-2013, 09:35 AM   #644
reg
Looking forward to giving mine a run tomorrow,
Which screws do you remove from the top brace to give more flex?
It's the pre 2013 and totally as kit,I just want to see what difference removing them all make on carpet,
Old 09-26-2013, 01:52 PM   #645
pcar951's Avatar
I think you'll be removing the top deck screws above the layshaft (4). Keep in mind that the layshaft is not fully secured once the screws are removed...But you'll get some more flex. If you're going to run it that way you should have the flex motor mount kit, P/N is R109022.
Jim Chapman
Tags
arc r10, rc-world, team titan
