Team Titan ARC R10 190mm EP Touring Car
#572
Hello,
I'd like to know if there is a shop that has the following part instock:
R103110: steel diff outdrives (this part comes from the R10 W)
I was unable to find this part in any webshop...
As I want to use a front diff with xhard putty, I'd like to use it without blade.
#579
#580
******ONE race old ARC R10 2013 for sale******
Original features:
2.25mm lower deck
Big bore short shocks
Low profile shock towers
Front spool
Rear gear diff
Option parts:
Split FR and RF suspension mount
Belt tensioner
1.6mm upper deck
Flex motor mount
Newly rebuilt after race
No damage. No crooked bulkheads etc
Light scratches on under chassis
Electronics not included
Price : USD 320
Original features:
2.25mm lower deck
Front spool
Rear gear diff
Option parts:
Belt tensioner
1.6mm upper deck
Flex motor mount
Price : USD 320
#581
2013 chassis
Hi
Can anyone give me the part number for just the 2013 chassis , not the conversion set.
Thanks in advance
Michael
Thanks in advance
Michael
#582
http://www.arc-rc.com.tw/image/r10_2...kit_manual.pdf
It is a far improvement over the original 2.5mm chassis
#583
R108009
Super , thanks for your answer. I will try One out within the next month!
Best regards
Michael
#584
parts
hi all
have a lot of xray t4 parts.
geared diffs
bearings
caster blocks
wishbones
drive shafts.
will these fit the arc 2013.
also how does it compare weight wise. strength and quality to the t4 as looking for a change.
thank you
geared diffs
bearings
caster blocks
wishbones
drive shafts.
thank you
