Like Tree1Likes
Old 06-28-2013, 06:36 AM   #526
Originally Posted by Hugo View Post
Hi everybody,
I'm interested in that car and I:d like to know if I can use hpi silver springs with the new "big bore" shocks which are shorter?
Same as with the t4 it might be possible with different spring cups. I was looking roughly at the length of yok springs and the potential is there.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-28-2013, 09:01 AM   #527
Hi Besercoe,
Can you tell me the lenght of the new ARC R10 short springs please.
Hugo
Hugo is offline   Reply With Quote
Old 06-28-2013, 05:16 PM   #528
trigger's Avatar
20mm
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 06-29-2013, 10:06 AM   #529
Originally Posted by trigger View Post
20mm
Old 06-29-2013, 10:36 AM   #530
Do you have a part number for a lower spring cup?
Old 06-30-2013, 02:26 AM   #531
There is no ARC Part (as yet), i was looking at Tamiya ball ends, and 1mm down cups, and it looks like it would be a close fit. You might need to make some slight clearance on the arm.
However there are plenty of spring options out there already for short shocks, ARC of course, Xray, and RSD all make sets of springs.
Old 06-30-2013, 07:20 AM   #532
Someone as used the internal pulley Xray (20T) in this car???
Regards
JordiM is offline   Reply With Quote
Old 06-30-2013, 11:53 AM   #533
trigger's Avatar
Haven't tried the xray pulleys in this car. The difference is negligible cause the xray ratio is 1.9 where as the arc is 2.0.
Minh Nguyen
Old 06-30-2013, 12:41 PM   #534
Looking to buy a ARC R10 if anyone has one for sale or trade?
missouri racer is offline   Reply With Quote
Old 06-30-2013, 01:21 PM   #535
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Drove last night on tight technical track in 108* weather. Car was very nimble and smooth the whole night. Got tooken out in main but still had a blast!!!!
Josh-n-ya is offline   Reply With Quote
Old 06-30-2013, 01:58 PM   #536
Maybe, but here racing rule is maximum Ratio 5.000 (10,5 blinky) if you use Xray pulley , whit the same Pinion/Spur the ratio is 4,75... ¿more faster?...
Old 06-30-2013, 06:07 PM   #537
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Gave my R-10 a run last night, nice!
Fitted with all the low friction stuff, 20mm steering swing arms, separate arm mounts, floating servo mount, Xray front bumper complete (15g lighter & allowed me to use an existing body)
For a first run I couldn't be happier...
Xray - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
Old 06-30-2013, 07:30 PM   #538
trigger's Avatar
The original R10 is a potent machine. I'm reluctant to convert it over to the newer specifications. However, my 2013 model handles freakin awesome so I want to make a twin for another class.
Minh Nguyen
Old 07-02-2013, 07:50 AM   #539
RC Professor's Avatar
Definitely considering this car, but wanted to get some feedback on a few things:
-Looking to run 17.5 blinky on carpet, rubber tire. Anybody been running this car with rubber on the rug? Is the newer more flexible chassis in the 2013 edition ideal for this type racing?
-What about shocks? Good quality, easy to build, repeatable performance?
-Hinge pin blocks - looks like there's a ton of combinations for toe in, out and track width. Do all of the various blocks come with the kit?
Thanks for any info.
RC Professor is offline   Reply With Quote
Old 07-02-2013, 01:21 PM   #540
trigger's Avatar
The ARC shocks are nice. Not quite as nice as tamiya or HPI but functionality is great. Easy to build and no leaks. Oring's are good so you don't need third party orings.
I haven't driven my 13' model on carpet yet but for sure the original R10 is good on carpet. But I'm sure the 13' will be great on carpet.
Minh Nguyen
Tags
arc r10, rc-world, team titan
