Old 01-11-2013, 02:41 PM   #316
ARC USA's Avatar
The car is little heavy overall and the aluminum screws with the lighter VTX1 is a better choice in my opinion.
For the oil i just use AE 37.5 weight oil. The cst ratings differ from oil manufacture but commonly a 350CST is like a 30 AE oil.
Originally Posted by nikos2002 View Post
Debating on whether to put VTX1 or VTX10 speedo in car. Difference is weight. How are you guys on overall weight with the car?
Sorry, electric off road guy at heart. Where are you guys starting with shock oil? From my understanding 350cst can be like 3 different measurements - would most consider that just 35wt?
Thanks guys.
ARC USA is offline   Reply With Quote
Old 01-14-2013, 11:19 PM   #317
nikos2002's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to nikos2002
Getting closer - painted a body tonight. Hoping to get out and run a test or two before Snowbirds.
Hobby Authority Distributions Marketing Director
** www.hobbyauthority-dist.com
Sponsored By: Maclan Racing, XRay/RC America, J Concepts, Xpert R/C, G Force USA, X Factory, Boom Graphics, Hobby Authority
nikos2002 is online now   Reply With Quote
Old 01-16-2013, 09:30 PM   #318
Has anyone tested the flex chassis? And how does it perform compared to the stock chassis. Thanks
Realtek is offline   Reply With Quote
Old 01-17-2013, 12:06 AM   #319
sosidge's Avatar
Tried it once on low/medium grip asphalt, found it was a little less responsive and generated a little more understeer. Wasn't a fan on that day, but I see that it is very popular in other racer's setups. I might try it again.
Old 01-17-2013, 12:29 AM   #320
pcar951's Avatar
Trader Rating: 19 (100%+)
I'm running the flex chassis and top deck on carpet. It makes the car a little more forgiving and maybe opens the setup window somewhat. The kit chassis is obviously sharper in the corners with very little flex. Not much difference on the clock for me, it's all about feel...a little smoother drive with the flex. IMO
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 01-17-2013, 12:12 PM   #321
What are you guys running for low/medium grip ashphalt? I have been working on my car for like 3 weeks now. Been getting better and better.Super fast, but a little on edge. I have not really messed with the roll centers, that will be this weekend. Thanks in advance. Here are some pics....
Team Titan ARC R10 190mm EP Touring Car-20130115_084024.jpg   Team Titan ARC R10 190mm EP Touring Car-20130115_084038.jpg   Team Titan ARC R10 190mm EP Touring Car-20130115_084004.jpg   Team Titan ARC R10 190mm EP Touring Car-20130115_084053.jpg
WEEZY is offline   Reply With Quote
Old 01-17-2013, 12:25 PM   #322
klaymon's Avatar
Trader Rating: 71 (100%+)
Not a specific asphalt trick, but a little way back in the thread someone mentioned changing the ackerman spacers from the stock 3 mm to as little as 1 mm. I did that on mine and it was a ton better. It looks like yours still has the 3 mm spacers in it.
klaymon is offline   Reply With Quote
Old 01-17-2013, 12:29 PM   #323
Check out my setup on Facebook in the arc driver group, Bradd Vercoe
Car has been very good of late
Basically half mm under all 4 blocks, long front link, long rear wheelbase, and no sway bars. Super easy to drive
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-17-2013, 01:04 PM   #324
Ok I will look at it. Taking the sway bars off didn't make it less responsive?
Old 01-17-2013, 04:37 PM   #325
pcar951's Avatar
Gotta try that...no sway bars, the car is so narrow and rolls very little. I haven't taken a sway bar off since the TC5! Thanks for sharing.
Jim Chapman
Old 01-17-2013, 04:39 PM   #326
Granted that it may not change direction quite as good, but the additional grip, and resultant corner speed is pretty impressive.
Oh i forgot to add, im using the Cyrul carpet setup inboard lower shock mount position also, check out the setup and give it a crack.
Old 01-17-2013, 04:51 PM   #327
I will have to compare the width,i have not noticed any significant difference, but yes i do agree that this car seems to roll less than most.
However i thought that a narrow car will roll more, and a wide car roll less?
Old 01-17-2013, 07:25 PM   #328
Thanks for the feedback guys.
Old 01-17-2013, 08:10 PM   #329
cyanyde's Avatar
Width doesn't define how much it rolls, CG and RC does.
Width affects roll acceleration/speed...
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 01-18-2013, 03:09 AM   #330
sosidge's Avatar
You can't isolate width from roll - changing width changes the roll centre, that will change the moment between the roll centre and the CG, etc etc etc. All geometry changes are interlinked in some way. Setup is a balance.
Tags
arc r10, rc-world, team titan
SEO by vBSEO 3.5.0
