Old 12-28-2012, 03:39 PM   #301
ARC USA's Avatar
I've tried lower front than rear and lower rear than front. The car never seemed to like it. It didn't feel balanced to me especially when the traction got higher. I like 0.5 shims all around when traction is high.
ARC USA is offline   Reply With Quote
Old 12-28-2012, 10:09 PM   #302
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Pretty excited!! Starting building my snowbirds car tonight!! Chassis prepped, wet sanded and glued. Spool, diff and shocks done. Can't wait to finish, wish my local track would re-open do I could get some practice time.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 12-29-2012, 10:03 AM   #303
pcar951's Avatar
Trader Rating: 19 (100%+)
I've found that arm sweep may be an advantage even on carpet. Without arm sweep, the car needs more steering input to get the same corner entry. Just didn't feel right at last nights club race. JMO
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 12-31-2012, 12:12 PM   #304
ARC USA's Avatar
Jim,
So did you go back to stock arm sweep blocks. I've tried number 2 blocks in the front running parallel no arm sweep and steering entry suffered. I then increased steering ackerman shim from 1mm to 2mm and got it back. Now it has smoother mid corner and exit but didn't sacrifice entry steering.
Old 12-31-2012, 11:08 PM   #305
Originally Posted by ARC USA View Post
Jim,
Hi
What is the max and min amount of teeth spur/pinion? 64 dp
HB-forever is offline   Reply With Quote
Old 01-01-2013, 03:46 AM   #306
sosidge's Avatar
Originally Posted by HB-forever View Post
Hi
It's in the region of 99-111 for 48dp, so you're looking at 132 - 148 in 64dp.
Old 01-01-2013, 11:54 PM   #307
pcar951's Avatar
Jim,
So far I've left the 2-2 blocks on the car, I'll be sure to try the 2mm ackerman shims. Thanks
Jim Chapman
Old 01-03-2013, 11:43 PM   #308
nikos2002's Avatar
Car is built!!! I just need Futaba to deliver my electronics -- and my local track to open back up, so I can run it!!!
Little anxious.......
Nick Malato
Old 01-04-2013, 01:09 PM   #309
ARC USA's Avatar
Sweetness...Post some pics after your done Nick!!!
Old 01-08-2013, 11:32 AM   #310
ARC USA's Avatar
Hey guys, one more thing i have found during practicing is making the wheel base longer in the rear (3mm front and 1mm back) frees up the car and and gives better mid corner. This is with the stock lower chassis on high traction carpet.
Old 01-09-2013, 06:00 PM   #311
making the wheel base longer will free it up? ordered some parts should be here by this weekend Ill post some pics this weekend once everything is installed! Loving the car so far.
WEEZY is offline   Reply With Quote
Old 01-09-2013, 07:03 PM   #312
On the ARC, i tihnk it has more to do with reducing the driveshaft angle as much as it does the actual wheelbase. I have been running full long (+2mm) for ages now, and the car has been markedly better than in kit trim. I could never get rid of a weird on power push at the kit middle position, and going short, would make the car squirrelly under power.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-09-2013, 09:16 PM   #313
I'll try that this weekend when I run!!
Old 01-11-2013, 09:27 AM   #314
nikos2002's Avatar
Debating on whether to put VTX1 or VTX10 speedo in car. Difference is weight. How are you guys on overall weight with the car?
Sorry, electric off road guy at heart. Where are you guys starting with shock oil? From my understanding 350cst can be like 3 different measurements - would most consider that just 35wt?
Thanks guys.
Nick Malato
Old 01-11-2013, 01:38 PM   #315
ARC USA's Avatar
The driveshaft angle is important factor as well and to reduce overall stress is important. Good Point!
Weezy- By moving the rear arms towards the back there is less weight on the rear tires thus allowing the car to rotate and free up the rear. I know it sounds counter intuitive but this is what is felt when driving the car.
Tags
arc r10, rc-world, team titan
