Xray T1FK05
#1246
Re: Re: Diff Question
Originally posted by wannabee
I was told you'll need to pull the diff. apart and lube them with AE diff. lube B4 running them...
KE
KE
uh oh... Can anyone else confirm this?
I notice the bearings also sound a little dry, I've not run the car yet so before I do... I am going to pull a seal off them and take a look. Guess I shall be opening the diffs as well.
Curious Stewartfan... did you run the car hard as soon as you had it assembled or did you follow the diff break-in procedure? They do seem really really loose outta the box.
#1248
Make sure you used the correct matched bearing/diff holder. There are two pairs. One is to run the diff high and the other is to run the diff low. Now if you used one from the high and one from the low, yes your rear diff will be lopsided...
That actually might be good for OVALS!!!!
#1249
prepping a new T1FK05 chassis...? Should you file down all the edges and seal with CA glue ... is this necessary?
#1250
Yes for the lower chassis, unless you don't mind replacing the chassis...
Sanding and sealing with CA will help prevent the chassis from splitting and cracking from impacts, and save someone getting cut from the sharp edges.
#1251
Thanks dude!!!
No doubt in my mind thats what i did LOL
#1252
#1254
Originally posted by acutts
Do you just take the sharp edge off slightly with a file and then seal?
I rounded the edges off with a file and then took a Qtip dipped it in CA and wiped around all the edges. If you look back a few pages you will be able to find out what others have done. Som file and sand and more..
#1255
Depends I think on your overall setup and the kind of track. If you run carpet, I think LOW is the way to go. Asphalt might require a HIGH setup.
#1257
Try AE's stealth lube, thats what I will be using once I open them up.
#1258
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
I also took a tip from Rob Love. You can use a nail file (thick ones) to take the edge down real nice.
Blake
#1260
Originally posted by dr_hfuhuhurr
Here's a good article...
Blake
Blake
