Xray T1FK05
#751
Nerf bars are normally to protect the undercarriage as you go over stuff...
A lot of people will purchase the protector..I don't see just how necessary it is...maybe I'll change my tune...but i'm not worried aboutthe mechanical layout of this car in theleast...
I can't wait to get it out on the track
#752
Hop-Ups
Aluminum Shock Bodies,
Spring Steel axles,
Front sway-bar (depending on carpet or asphalt)
Extra rear shock tower (miraculously I have broken the rear shock tower...so I stack two on top of eachother)
Spool (Although moding the front diff that comes with the car, works fine)
Spring Steel axles,
#753
wow. how do you break a rear tower? curious.
#754
Re: Hop-Ups
Whats the diff between the spring steel axles, and the stock ones. Also what is the part number for the aluminum shock bodies and will the ones off the fk04 fit?
Spring Steel axles,
Spring Steel axles,
#755
one is spring steel, stock aluminum. so it bends easier and bends out. and the wheel chatter is supposedly from the unroundness of bent alumiunm ones
#756
Re: Re: Hop-Ups
Aluminum Shock Bodies - #308320
Pretty much what greencactus said, if you are running on a track that is very solid, and you tap a wall then the steering knuckles will "stretch" (in amount of steering), and turn enough to where the universal hits the aluminum axle and bends it. Although, I have never had wheel chatter in my xrays.
-Mike
#759
I 've built the 05 and the only thing that really bothers me is the shock quality. Is there anything that you people would recommend to replace them. I 've heard that Tamiya's would do, but I want to know which ones and also how they will fit. Is there anything I have to do to make them fit?
Any other options or opinions whatsoever would be very much appreciated.
Thanx guys in advance.
#761
Some people have a hard time building them, and not having air bubbles inside when they are done, OR they do not like the plastic bodies and the threads sometimes strip...why I get the aluminum shock bodies.
-Mike
-Mike
#763
Uh I thought they do come with the multidiff....
http://www.teamxray.com/teamxray/pro...1&menu_id=1281
#764
#765
Re: Multidiff
Originally posted by MrRolla
Does anybody know where i can find a multidiff or havent these been released yet? I decide to buy my kit from the US only to find out it doesnt come with the multidiff
Cheers
Cheers
