Xray T1FK05
#5371
hey guys,
just ordered a 83t spur and 30t pinion to get a ratio of 4.70 (recommended to me) does anyone else run these? if so how well does it run in the 540 class?
#5373
Had a question. I have an FK05. Been around the block a bit but still in decent condition. My concern is that I have pretty much always had to "fight" the car to go straight. Most people say my servo sucks but the guys at the store say its a decent servo, not great but not bad. Ive pretty much always just dealt with it but its embarrassing to a point where people are trying to help me but it just wont center or I cant accelerate without having to steer it straight.
Ive always noticed that the belt rubs on the servo saver. I cant move it or adjust it ... or at least I dont think I can. My thinking is that this belt rubbing onthe servo saver is moving the steering assy ever so slightly. Could this be happening or do I just need to spend $100 on a servo ?
#5374
It may be as simple as adjusting the trim on your Radio. Or what I would check is that your Servo saver (that you don't need because it is built into the steering rack) may be stripped and causeing the saver to click back and forth between two differant places, thus letting you never have a car that will go straight because it is changing in every corner. When in doubt start over with the steering system. Make sure all you links ar the right length and that your steering throw is correct and even both directions. There is no binding and no bad parts. If you need to you can always shim your servo out to get it off the belt. Alot of guys have to do that on the T2 and 007.
If this doesn't help give us more info.
RedRocket
RedRocket
#5375
I zeroed out the radio. Actually I am referring to the servo saver that is on the chassis and attached to the rods that go to the steering arms. I have a regular servo horn on my servo. That does not hit anything. The belt rubs against the metal part of the saver since the belt has enough room on the gear to move back and forth. Im just wondering if the belt rubbing up against this is enough to affect the steering.
#5377
Check the diffs,as they may need rebuilt. The original diffs had a defective thrust bearing, if that hasn't been replaced, that could affect torque steer. Also, I looked at mine and my belt rides as far right on the front pulley as it can and still clears the steering rod by a MM. You may have a problem with the front pulley being off set too far right and that could cause a bind in the front drive train causing it to pull.
#5378
#5379
I replaced the thrust bearing. But my diffs probably need to be rebuilt but they seem fine enough for now.
Dotman - that pretty much describes what is happening. I will check that out. I think im gonna start with the servo horn because it does move a bit more than I think it should but I just thought it was usual little bit of slop.
Thanks all for the suggestions. Will keep y'all updated.
#5381
Does the mamba max motor (CM36) fit ?
Hi guys,
Here is my question : does the brushless mamba max motor (CM36) fit in the T1 FK'05 ? I read (but I forgot where) that the CM36 is a 550 (not 540) motor-size.
Thanks for the answers.
Cheers,
Blin.
Cheers,
Blin.
#5382
is a tk05 still competative against the newer cars?
#5384
http://www.teamxray.com/teamxray/new...a1cfe48d29a447
It just won the master class of the US Touring Nationals 2007 two weeks ago. So yes it is
#5385
Mine still makes the occasional A Main
