Xray T1FK05
#4081
Originally Posted by teamgp
That shouldn't happen at all. In my early days with these shocks, I have made the mistake of pushing the two asdjustable piston pieces together without lining up the notch/grooves and stripped the notch. But I replaced the piston pieces with new ones and carefully assembled them.
I've never heard of this problem here or on the XRAY forum until now though. Do you still have the shocks? If so, PM me.
on my fk05 i built them with fixed pistons.
#4082
Regarding to the serpent shocks, I'm a little bit confused:
According to serpent's information ( http://www.hobbymodels.ch/att/960manual.pdf ) the front shocks are 68mm long rears are 73mm. I measured my xray shocks and they are about 68mm long (nowhere close to 73). So I would assume that not the rear ones what we need but the front ones. Especially when using foam front shock tower.
I have a buddy in Europe who just installed front serpent shocks on his xray and he says they fit perfectly however in this thread everybody states that the rear ones what we need. I'm confused...
BTW: At least five people have asked where to get them - but nobody wants to answer that simple question. Wondering why?
#4083
Anyone here who successfully has their tamiya shocks on their fk05 please help me. I'm having trouble becuase the shocks seem to be too short.
#4084
#4085
to help maybe . . .or confuse more i think the shocks part #903165
might be rears shocks on the 710 and front shocks on their 1/8th scale S960
i am not 100$ sure . . .
#4086
For tamiya shocks, use TC3 shock ends, they should work fine, and you can also use the stock ball to snap them onto.
#4088
Thanks DougC, I read back but I missed your post
About the shocks, I don't think that Serpent would sell the shocks for 710 on a different name...
http://www.mytsn.com/products/desc.asp?prid=4156
#903164 – Shock absorber set RCC FR (2) (68mm long per the manual)
#903165 – Shock absorber set RCC RR (2) (73mm long per the manual)
Could somebody please confirm what is the lenght of the Rear Serpent Shocks and also what is the length of the xray ones?
#4090
Here's another update on the one-way foam/carpet setup. It seems to be perfectly dialed for foams on high grip smooth asphalt (The Coliseum, Frederick, MD) as well and only needs a few minor changes for running rubbers on the same asphalt surface.
http://www.teamxray.com/xforum/viewt...?p=25408#25408
#4092
Does the FK05 chassis fit the new 3700-3800 cells?
Thanks.
Thanks.
#4093
yes with a little filing
#4094
Fitment of new cells in chassis
Thanks.
Thanks.
Later,
#4095
Originally Posted by CRASH
I was under the impression that they didn't. But my new FK05 fits them perfectly with no modifications at all. The same is true for my 3mm chassis I just got.
Later,
Later,
