Xray T1FK05
#3601
Originally Posted by HarshGuy
What did you have to do to get the foams to "fit" on the rear w/the tamiya shocks?
#3602
Whats up roger...
#3603
Originally Posted by Roger
Jav: Im using the stock xray shocks. I had to dremel down the rear shock mounting holes on the arms to get clearence.
#3604
Originally Posted by dal bains
Whats up roger...
Harsh: Goodluck at Vegas. I'll scan a copy of that set-up after tommorrow's session at Gilroy.
#3605
Can anyone tell me if you can run a Kimbro spur without...
any mods? I remember reading this sometime back and I wondered if the new kits will?
#3607
hey tim, i like the 120 alot on my car, like you said for stock... it works awesome.
#3609
Hey Guys. I was wondering what people do to get there cars to carry more speed in the corners? Do people turn up the throttle trim so it helps roll more in the corners.
It just seems like people eat me up in the corners and I tried a few things but nothing worked. I know its a deep question but does anyone have some tips to keep my car carrying speed in the corners? I guess it would be driving style. Any Suggestions on driving style.
#3610
Wuzzzz Up Dal !!!! I've noticed that you joined the darkside
Yea that would be great, me, Dal, Robert, Aaron, Nick, EJ, Jim, Juan (I'm sure I missed some norcal names that I'm not that familiar with) are gonna hit the Vegas race, should be fun!!
#3611
Hey guys, I posted some pics of the forthcoming fk05 Hyperform Carpet Conversion on our thread as well as our website. You can also read more about the conversion kit on our website. Check it out and let me know what you think.
#3612
http://www.teamxray.com/xforum/xsheets.php
#3613
I noticed in the setup sheet section that when some of the guys running a spool on there Xray FK '05 touring cars they all run 0 degree caster blocks when running these blocks does it give the car more or less steering with the spool.and what is the reason for running these blocks
#3614
Decreased castor will help recover some the initial turn in lost by the locked up front end and reduce cvd deflection from the spool alowing for greater wheel turn before chatter begins.
Mark
Mark
#3615
yeah wheel chatter can be quite an issue especially if your on a very tight circuit and thats the type of circuit we would sometimes would run the 0 degree caster on the FK05, to counter entry understeer and usually with a little kickup on the front to help weight transfer also. The narrow axles work well to counter that problem as well.
Good result in the UK last weekend for the FK05 at the last BRCA Mod National. Darren Stlyes finishing 3rd in a really competitive field, car was working really well. Top 4 was
1st Chris Grainger - Yokomo
2nd Craig Drescher - Associated
3rd Darren Stlyles - Xray FK05
4th Andy Moore - Hotbodies Cyclone
