Bodyshell Handling Characteristics....
I was hoping some of you could list the bodyshells you've tried and what you found they gave you with regards to the handling and did any of you end up with the same findings I found.
I know this has been asked before but I've had trouble finding a relevant thread.
Protoform Dodge Stratus Very safe- too safe for liking, possibly good for beginners as they were what I started with.
Protoform Mazda 6 Still a bit safe but a step up from the Dodge's, very consistant
Protoform Mazda Speed 6 Gives more steering and still fairly stable.
Protoform LTC-R Even more steering and can be a bit edgy but that seems to depend on the track.
Eastcoast M Speed 6 Similar to the LTC-R, I've found it quite good on carpet
Protoform R9-R Closer to a Mazda Speed 6.
Protoform Alfa 159 I bought this to use on my wet car to give more steering but it seemed to be more like the Mazda 6
The P37 seems to be a mix of LTC-R and Speed6. More stable than the LTC-R and more steering than the Speed6. But still a bit more unstable than Speed6 and a bit less steering than LTC-R.
What about the RideRC Subaru ???
How does this body proform ???
My experience with these bodies
Dodge Stratus - higher the grip the better this body works. Very neutral and stable.
Mazda 6 - prob best rear grip of all bodies. Good steering. Very stable
Mazda Speed 6 - prob best all round body because of better steering than its cousin the 6 and retains most of the rear grip. Since most people use this body more setups are available for this car.
LTC-R - almost too much steering. Can be a little loose in the rear if not exactly set up right.
EC Sp 6 - never tried
R9-R - never tried due to the fact that ive only seen one person get a car dialed with that body. Heard that it has extreme steering yet no rear grip.
I drive a Protoform Mazda 6 and a Audi S5 at the moment, and probably will stay with them since 99% of the drivers around here use those bodies. I find the Mazda 6 to be a pretty much allround body, while the Audi S5 has more front end grip
Normal Mazda 6 or Speed 6?
Normal Mazda 6. I did however use a old Protoform Alfa 156 during most of the last season in our 13T blinky, finishing 2nd overall in the championship. I found the body to be superior on fast tracks because in my opinion it created less drag then others. On technical tracks I used a HB Subaru Impreza Type B. I didn't try these bodies on my new car in boosted 10,5T since the Alfa is now a shelf queen and the color started to peel of the Subaru almost from the beginning- now it is in a horrible state
Has enyone tried the East Coast Speed6 body? Any feedback on it?
Having recently gone back to a PF Speed 6 as I did too much damage to the East Coast M Speed 6, I can say that the PF version is a lot safer/easier to drive on tight carpet layouts.
I might patch up the East Coast and try it outside again.
SKiddins
SKiddins
How about Titan WRX?
Best regards
Best regards
