Like Tree9Likes
Old 05-17-2017, 10:24 AM   #106
Bar
Originally Posted by Skiddins View Post
5mm as that's how far forward Bitty said their pre cut version would be.
LTC2.0 was 4mm forward.
IS200 was asphalt pre cut
Good to know, I will be getting a pre-cut M410 as soon as they are available, did you mount the wing in a neutral position?
Bar is offline   Reply With Quote
Old 05-17-2017, 10:26 AM   #107
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
5mm for me also
Old 05-17-2017, 01:51 PM   #108
Skiddins's Avatar
Yes.
You might want to get some of the foam for padding the gap between the bumper and the splitter as well as the gap is pretty big, around 15mm or so
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-17-2017, 02:18 PM   #109
Bar
Yes.
Wow that's a lot, will do cheers
Old 11-03-2017, 10:29 AM   #110
Reading this with interest. on a side note, how much difference do the wing end plates make with aero? and are they worth putting on?
stuartkeith is offline   Reply With Quote
Old 11-03-2017, 11:26 AM   #111
wtcc's Avatar
I never felt the difference running mostly 13.5t and 17.5t. In theory there should be a small downforce and drag advantage, 2-5% I would guess. But with all the vibrations while running and the speeds we drive, I don't think the aerodynamic efficiency of the rear wing works like it does on 1:1 cars.
Nevertheless the look is good, so my last bodies all had end plates.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 11-03-2017, 04:14 PM   #112
Skiddins's Avatar
With higher speeds on asphalt tracks, boosted 13.5 and Mod etc they can sometimes help a little with stability, but not essential.
Blinky classes they're not even worth the bother.
Though I do prefer the nice rectangular look when they're fitted
pphaneuf likes this.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-03-2017, 04:20 PM   #113
Skiddins's Avatar
Also have an M410 that is mounted 7mm forward and is virtually my go to bodyshell for asphalt.
Compared it to my Montech Nazda 3 (my previous 'go to') and it had a bit more steering, though the Nazda3 felt slightly more stable, and felt like it carried a bit more corner speed.
Both are very good.
I currently only run the IS200 and LTC2.0 on high grip carpet.
Have a Montech Racer, but it isn't painted up yet.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-03-2017, 05:23 PM   #114
wtcc's Avatar
The Racer has even more steering than a forward mounted M410. It is the body of the month in southwest Germany right now. We run it indoor and outdoor.
Old 11-03-2017, 05:31 PM   #115
LOW ET's Avatar
Trader Rating: 97 (100%+)
where are you buying the racer bodies from?
LOW ET is offline   Reply With Quote
Old 11-03-2017, 06:55 PM   #116
Skiddins's Avatar
I've had mine about 6 weeks, keep forgetting about it and when I remember I don't have the time to actually paint it;
Demon Power Products - Servicing Radio Control Cars Since 1978 - 01252 343132
Even the one I bought back then IS the correct approved part number.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-04-2017, 10:59 AM   #117
Location: Beneath a rock down by the river. Don't have money for van
Yes they are but don't use them right on the wing, drop them enough to touch the boot, sealing that area and maximising the wing on cut bumper effect
Oops shared a secret...
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 11-06-2017, 10:04 AM   #118
Barry_Hughes's Avatar
only if the rules allow it, that would be failed in scrutineering in most if not all major UK races
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 11-06-2017, 11:10 AM   #119
snuvet75's Avatar
Trader Rating: 15 (94%+)
Nardo vs m410 anybody on asphalt?
snuvet75 is offline   Reply With Quote
Old 11-06-2017, 11:48 AM   #120
Just lower the endplates already cut. They have to be mounted on the very lower part of the wing,which has to be the ones with the middle raised.
Xray XB9 rfleck Nitro Off-Road 5476 11-07-2016 04:38 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
