Like Tree5Likes
Old 05-05-2017, 07:04 AM   #91
Skiddins's Avatar
Anyone have any of the newer bodies to add to the thread?
I'm in the middle of painting up an LTC2.0
Hopefully I'll shortly have a Bitty MC410 and an IS200 as well.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-05-2017, 08:35 AM   #92
Metalsoft's Avatar
Trader Rating: 69 (100%+)
Originally Posted by hannhann00 View Post
Hi has anyone tried the Protoform PFM-10 and would this be legal in most normal level TC races, or only for classes like USGT? How would it compare handling wise to some of the mentioned shells?
I run this body in USGT. It has a ton of steering, Mid corner and exit, however it does struggle a bit if you have a long straight away
For a tight track it would be perfect.
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 05-05-2017, 08:38 AM   #93
daleburr's Avatar
I'm running the IS200 regularly now. It's very similar to the LTCR (not surprising as it looks like they started out by pouring plaster into an LTCR!). Maybe a bit more steering, and a bit more stability. So overall a really good shell. And pre-cut is a great invention.
Haven't heard much good about the LTCR2 I'm afraid.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 05-05-2017, 09:03 AM   #94
Skiddins's Avatar
Was that carpet or asphalt pre cut, and how far forward does it mount, compared to having the front wheels dead central in their arches?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-05-2017, 09:38 AM   #95
RobS's Avatar
The more I run the LTC 2.0 the more I like it. At first when I just put it on using the same setup as I did with the LTC-R I didn't really like it. Felt it didn't turn in that well, but did have a lot more rear grip then the LTC-R. After a bit of tuning however the 2.0 turns in nicely (but still not quite as aggressive as the original), and rotates the corner much, much better. The track I race on is on the smaller side and grip can very from low, to very high, CRC grey carpet track.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 05-05-2017, 09:41 AM   #96
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
so far i ran the bittydesign Nardo on asphalt and the M15 on carpet and they are by far better than LTC and the Mazda's. I just finished the Bittydesign M410 to try out in the next few weekends.
Old 05-05-2017, 09:55 AM   #97
daleburr's Avatar
Mine wasn't actually pre-cut, as it was on the shelf for ages before I got round to cutting it. It's flush with the old Xray bumper, which I think is about where the Carpet pre-cut comes. That's how I run the LTCR at Bedworth as well, as I like a stable car there.
Luke has the asphalt pre-cut, which is flush with the new Xray bumper, so maybe 5mm further forwards. So more how I'd run it at WLRC/Cotswolds.
Team Xray
Old 05-09-2017, 05:12 PM   #98
Skiddins's Avatar
IS200 and LTC2.0 at Aldershot (13.5 boosted)
IS200 was a borrowed body, a few mm forward with the wing mounted waaayyy back.
In the morning first round of quali my new LTC2.0 had good steering, but the reduced traction meant the back was a little unpredictable on power out of the tighter corners.
By round 2 the tracks grip had come up slightly and I put the borrowed IS200 on and went 1.5 laps faster.
I kept that on until the last final when I went back to my LTC2.0
By this time there was easily enough grip to use it and lap times were comparable (couple of tenths slower, but so was everyone else, so LTC2.0 performed about the same as the IS200)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-09-2017, 06:51 PM   #99
Super Moderator
Marcos.J's Avatar
i picked up a few tenths going from the ltc 2.0 to the bitty Nardo, i got the M410 to try it out this weekend
Old 05-09-2017, 06:57 PM   #100
nexxus's Avatar
Trader Rating: 301 (100%+)
On an open asphalt track I am finding the M410 very very stable, but you lose a bit of top end compared to the MC10 body shell. MC10 works well if grip is a bit higher and is very neutral. M15 didn't really work, probably best suited to carpet.
Marcos.J likes this.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 05-09-2017, 07:08 PM   #101
Super Moderator
Marcos.J's Avatar
m15 is great on carpet
Old 05-15-2017, 06:29 AM   #102
Skiddins's Avatar
Now have run the Pre cut Montech IS200, LTC2.0 and Bitty M410.
Running the LTC2.0 last weekend I found the rear a little unstable coming out of corners, but a change to a borrowed IS200 (with std rear wing mounted waaayyy back) felt immediately better.
This weekend I ran all the bodies in subsequent quali rounds at my local track.
Track was dustier than expected so grip, and laptimes were down on the usual.
THe M410 came out on top as it had the steering of the other but was very stable at the rear (except when gusts of wind upset it).
The IS200 was next as the back just wasn't quite as planted as the M410.
The LTC2.0 just felt even more unstable.
It should be noted that the lap times etc were very similar and the track temp steadily rose throughout the day.
I want to test the same bodies again, but in a different order and also test different wings and positions.
Lonestar, Marcos.J and LonnyJ1950 like this.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-15-2017, 05:53 PM   #103
nova2015's Avatar
Having tested a few bodies recently too, my findings were similar to yours. LTC-R turned in strong, but felt unstable in the rear. LTC 2.0 was more stable in the rear, but did not turn in as well. Bitty M410 was the best all rounder, similar turn in to LTC-R, but with good stability. Lap times back this up, with it being consistently faster, with marginally quicker race time.
This was done in 21.5, using same setup and same tyres.
nova2015 is offline   Reply With Quote
Old 05-17-2017, 06:28 AM   #104
Bar
How far did you mount the M410 forward?
Bar is offline   Reply With Quote
Old 05-17-2017, 08:07 AM   #105
Skiddins's Avatar
5mm as that's how far forward Bitty said their pre cut version would be.
LTC2.0 was 4mm forward.
IS200 was asphalt pre cut
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Xray XB9 rfleck Nitro Off-Road 5476 11-07-2016 03:38 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
