Old 07-01-2002, 08:08 AM   #1
Default HPI 2 speed ELECTRIC
Hello all,
I did a scan on the search, but most of the answeres were for nitro trannies.
My questionis this:
I just got a used RS4 sport and bought a 2 speed for it. While i was setting it up, the spur gear would spin in OPPOSITE direction ONLY. this is when I was holding it in my hand. When I installed it in the car, and put the double pinion in, it obviously only spun in ONE direction. When I tested the car, it seemed to take off the line very fast and the top end speed was fast too. I have a 13 T motor in it and the tranny and spur and pinions are the stock HPI ones that come wiht the set. I have been reading on the forums that the Nitro cars, have a sound change from one gear to thte other, is this true of the electric cars???? Cause even theough the car is fast of the line and top end, i do NOT hear any speed change from gear 1 to gear 2!!!!! do i have to loosen the clutch? I have left it at factory default. Please help.
PS: I found something that said 2 speed trannies are worthless on electrics...is this true?
billymou is offline   Reply With Quote
Old 07-01-2002, 04:45 PM   #2
Joe's Avatar
billymou, I think two-speeds are fine for bashing but worthless racing. Not to mention illegal. As for the shifting you describe, that sounds fine, that's how it works. When the 2nd gear kicks in, it needs to bypass the first gear. It accomplishes this by using a one-way bearing on first gear.
Joe is offline   Reply With Quote
Old 07-01-2002, 05:40 PM   #3
You can't hear the tranny shift and once you get about 1/4 of the way thru your pack you it won't even get enough juice to spin the motor up to enough RPM's to shift anymore.... It's more of a novelty item than anything.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Electric MT Speed control nerdling Australian Racing 3 04-18-2006 01:45 AM
Electric 2 Speed! LosiFromHell986 Electric Off-Road 0 12-23-2003 08:10 PM
RS4 MT Electric w/ 2 speed Michal101 R/C Items: For Sale/Trade 5 08-05-2003 06:52 PM
Electric TC3 2 Speed DraKhen99 Electric On-Road 30 07-22-2003 07:37 PM
2 Speed Electric Touring Car thefuzzclub Electric On-Road 5 06-02-2003 09:32 AM
SEO by vBSEO 3.5.0
