Tips needed on drilling and countersinkng carbon plates
Hi. What kind of countersinking tip do I need for m3 screws? There are many different kinds here and i don't know which to use. What kind of drill bit should I use to avoid splintering? Holes I need to drill are very close to the outer edge of bottom deck. Thanks in advance.
http://www.mcmaster.com/#drill-bit-countersinks/=gzt2re
If you go by the catalog at McMaster, the flat head M3 screws that they carry are 90 degree head angle.
A standard countersink works if you go slow. Use a drill press if possible. Standard HSS bits work for drilling.
Clamp the carbon to some mdf or plywood which will help prevent splintering. And only use new, sharp bits and feed it through slowly on a drill press. I use HSS drills and countersinks, but they do go blunt quickly
Yes, metric countersinks are all 90 degrees - same as a normal drill. HTH
For consistent results with the countersink, use a depth stop on the drill press.
Solid-Carbide Drill-Point Countersinks
http://www.mcmaster.com/#countersinks/=h0580x
Nothing better. You want 90 degree for M3
Thank you all
